Looks like you are only loading one core. Try this... http://www.overclock.net/downl...-orthos-v20060420.html
Originally posted by: myocardia
Originally posted by: ja1484
While that *definitely* could be the case, and the OP should *definitely* look into it, the blanket statement just isn't true. The OC in my sig is actually undervolted from stock, running on 1.30v, and it's 36 hour Orthos stable.
Edited to add: Also, the previous CPU I had in this machine, a 3000+ Winchester, ran @ 2.2Ghz (from 1.8ghz stock) on 1.325v, 24hr Prime stable.
Anyone can try undervolting any CPU, but no matter what lies AMD likes to tell, nearly 100% of all Skt. 939 CPU's require more than 1.30v (as evidenced by your 3000 Winchester), yet AMD told all of the motherboard manufacturers that they only require 1.30v, which is why nearly 100% of all Skt. 939 BIOS's default to 1.30v. BTW, 10,000 hours Orthos stable does not mean your system is stable.😉
Socket 939 BIOS's, in my experience, default to the default voltage of the detected CPU. If you take them on to manual settings, you'll usually end up with 1.3v, but then...you're on manual, so what it detects is immaterial.
And of course Winchester required more than 1.3v - it's specs note 1.35v at stock, just like they did with the Manny. Nevertheless, they're running OC'd and undervolted.
As for that bit about Orthos, that's just FUD - everyone knows Prime/Orthos is the standard stability test for OC'd CPUs. There can always be stability issues from other components, if that's what you're roundabout trying to get to, but the CPUs are not the problem in that situation. Hell, crashes can come from *bad code*, technically meaning your system is stable or not depending on what it's running. You're splitting hairs, and you knew damn well what I was getting at.
Oh, from your experience. Exactly how many Skt. 939 CPU's have you owned so far? I've only owned 6 or 7.
And the only FUD so far in this thread hasn't come from me, bub. If you actually knew much about overclocking, you'd already know that Prime95/Orthos stability guarantees nothing more than the ability to be able to run Prime95 or Orthos error free; it does not guarantee complete stability-- far from it. It only guarantees that your system isn't completely unstable. Sure, it's a good start, but it far from guarantees complete stability.
BTW, two of my 6 or 7 Skt. 939 CPU's would fail Prime95/Orthos in seconds, at 1.30v, and most of the others would fail in less than an hour, at the same voltage. Yet all magically passed for as long as I let them run, when given the proper voltage, 1.35v.
Oh, and if I'm splitting hairs, why exactly did you post this:
Originally posted by: Finns14
Ok well with the side of my case off and a room fan blow directly on it the stress test seems to be working better now, I made it to test 3 where as I was failing in about 1-2 mins for test 1. Do you think its because of my mistake with the thermal past or just the fact that I am using a crappy AMD stock HSF?
It's because you aren't giving your CPU enough vcore. Skt. 939 CPU's require 1.35v.
It can go both ways, we might as well leave it at that.
Prime/Orthos is known as the standard initial stability test for an OC'd CPU after settings have been determined.
And please stop talking about "system" stability. We're discussing the CPU here, not the wild, piss-stained swamp of entire build stability.
Get luckier when buying chips then.
Primarily to refute your erroneous claim above. We've been over this.
Yes, I know that. That was exactly the reason that I told him to give his CPU 1.35v of vcore. Or have you already tested his CPU, and know that it's one of the few that runs fine @ 1.30v?
Really? I didn't realize that. I've only been overclocking CPU's for about 17 years so far. You?
What kind of idiot would want to make sure their CPU was stable, yet get 5-10 BSOD's per day, along with 3 or 4 reboots, just to mention two of the many things that can and do happen with an unstable computer?😕 I don't think I know anyone that dumb. Do you?
Yet you still don't get the point. Why exactly did you say that the CPU in your sig is undervolted, if you don't think it's undervolted?
BTW, your CPU is undervolted, in case you were wondering. That's why your overclock is so low.
Could be your TIM application, or poor case ventilation. However, the stock HSF should be fine if you aren't overclocking.
FYI: Don't test system stability with Alpha, or Beta software as LOUIS suggests. Beta code has bugs that could be mistaken for hardware problems. That's why it is not available for download on the main page. 😉
If you look at the latest version, people are having problems with it that could be interpreted as hardware problems.
THIS IS A PRE-BETA VERSION - NOT FOR EVERYDAY USE
