0roo0roo
- Sep 21, 2002
- 64,795
- 84
- 91
Originally posted by: spidey07
Originally posted by: 3chordcharlie
Yeah, you'll probably find that at least 10-20% of your total area is covered by plants, and way more than this if you use any ground covers. You'll need less than that in subsequent years, depending on what you put down, how well it stays, and how bad you think it looks as it fades.
BTW: The number one mistake I see from both homeowners and landscapers with mulch is piling it around trees and woody plants, possibly thinking it is protecting something. There should be no mulch touching the bark of a tree or woody plant. It does the same thing to trunks as a bandaid does to your finger when you sweat (soggy!). Once this happens, insects and mould/fungus-type problems will make short work of most trees.
ooohhhhh, good stuff. Any ideas on treating bare clay soil with food for re-planing/splitting bulbs and hostas?
So keep the mulch away from newly planted shrubbery?
I demand shubbery! Bring us shrubbery!
just keep a bit of a ring of clear around the trunk area and it'll be fine. always need more than you think to get that 2-3 inch depth
