Previously Working Wi-Fi problem
Duder1no
866
My previously working Wi-Fi all of a sudden developed an intermittent problem, my laptop and my iPhone all of a sudden cannot connect thru the WiFi to the internet, my PC and my PS3 connected thru Ethernet to the cable modem have no problem connecting to the internet, the cable modem indicator lights and the cable modem WiFi settings page indicate nothing wrong, my iPhone WiFi connection settings page indicates intermittent on/off (~1 second) WiFi connection, any ideas how to fix this?
Cable modem: Ubee U10C020 Wireless EMTA
OS: Windows XP Professional, SP2
airdata
4,987
On something like that, I'd probably get w\ support from your isp and see if they need to replace the router.
My FIOS router was doing something similar where the wifi just kept dropping off. They just sent me another router and it fixed the wifi issues.
Duder1no
866
that's exactly what I suspected: defective router
but I wanted to see if there was anything that I could check before reporting it to my isp
thanks
JackMDS
29,563
432
Hmm. I would not rush to get a Wireless Router.
Your network topology sounds "Fishy".
I.e. you have devices connected directly to a modem. and others through WIFI.
May be you want to describe what devices you have and how every thing is connected.
:cool:
Duder1no
866
Well I have my desktop PC and my PS3 connected to the cable modem thru ethernet cable, and my laptop and iPhone connected thru wireless.
Duder1no
866
ok I just went into the modem settings page, returned all wifi settings to default, chose channel 6, assigned the same previous wifi password and it worked!
i had been playing around the settings and I enabled "guest WLAN network" and i guess it didn't like it.
thanks for your help guys.
JackMDS
29,563
432
It seems to me that what you call a Modem is a modem/Router.
If you have a second Wireless Router connected after a Modem/Router, the Wireless Router should be configured this way.
Using a Wireless Router as a switch with an Access Point - http://www.ezlan.net/router_AP.html
:cool:
Duder1no
866
:cool:
I don't know what it is really, is it a Modem/Router?
http://www.ubeeinteractive.com/index.php/products/product-overview/wireless_emta/
http://www.ubeeinteractive.com/data-sheet/U10C022_datasheet.pdf
JackMDS
29,563
432
From the Data Sheet.
Key Features & Benefts
• Robust routing capabilities of RIP,
VPN and static routing
Enables value added product offerings for business
that require commercial routing capabilities.
• Integrated voice, data and wireless
Reduces OPEX, by eliminating the need for multiple
devices in the home or offce. Enables Home
Networking product offerings for Cable Operators.dd
It actually a Router on "Steroid". :thumbsup:
:cool:
