Originally posted by: Sir Fredrick
Originally posted by: dclive
Rest assured no program has that, as long as you log in as admin, excluding some malware.
Are you a programmer? I am. If malware can do it, any program can do it.
Of course. But the fact is that programs don't. They prompt you, and when you click OK or FINISH, they reboot the box.
I've asked that you send me a link or information on this program that didn't even inform you it was rebooting your machine. You didn't. I can't believe such a program exists. Typically they'll state something like "Click OK to reboot your system", and hence, you've given permission to reboot your system. In fact, you wrote:
I did. It was the software that comes with the Rio Nitrus. It does inform you that it will reboot your machine, but does not give you an option to stop it from doing so, and even killing it does not prevent it from rebooting your machine. I do not call that giving it permission to reboot.
You were prompted per page 9 of your Nitrus manual. What other notification should there be? If you say OK, it will reboot. If you don't want it to reboot, don't click OK until the next "reboot time" you've set aside.
Considering that anyone NOT logged onto the machine can reboot it, this isn't preventing anyone from doing maintenance. It's not a perfect fix, but it's the only way I know of to prevent an application from rebooting your machine even if you haven't given it permission to do so.
Anyone not logged into the machine can reboot it? Not without appropriate access or a poorly patched box.
You keep repeating this "even if you haven't given it permission to do so", yet clearly, you have given it permission to do so - so why do you write that? I think what you want to do is to be able to click a box saying "Yes, reboot my machine!" while having the application/operating system do nothing. Hopefully you can see how confusing that would be for users. The point of the application install is to ... install the app (or in your case, a device driver) -- and if it wants users to reboot (due to replacing active files, hitting pending file rename tables, or whatnot) they should reboot....and they should be reminded to reboot. But the user does have the option to ignore that reboot notice and not reboot.
