pretty hot: usb Bluetooth adapter v1.2
Brian M
Originally posted by: Jaxidian
Class 2 uses less power but also has a smaller range. This smaller range can be both good and bad. Good for security, bad for convenience. You make the call. :)
edit err, I had that backwards. Class 1 is the shorter range, Class 2 is the longer range.
No you were correct initially. Class 1 is 100m and Class 2 is 10m. The OP has this backwards too in his post.
nivw
117
I help my comment is not considered OT, just something I wanted to ask about the BT thingy:
I saw a post about Mobile action MA-720 . what does that adaptor has that this doesn't?
Does it enable me to connect to my pc via the headset while accessing the web from my cell at the SAME time?
Niv
Jaxidian
2,230
twitter.com
Niv
Looks to me that it has some additional software that comes with it that is programmed for some 50ish phones. Perhaps it's good software or perhaps it's crap - I can't tell you that, unfortunately.
joeld
341
I've had good luck with zonet in the past -- might have to get another one of these (gave mine to a friend for b-day).
mrSHEiK124
11,488
If you got a Class 1 (100M) device for use with say a mobile phone or a headset or something, it really wouldn't make sense as they are all Class 2 (for power consumption reasons), someone made a good analogy of it somewhere, if you throw a baseball to your baby brother who is 100 M away and he somehow caught it, it wouldn't matter cause if he threw it it'd barely make it 10M back.
SuPrEIVIE
2,538
if they are class 2 shouldn't the range of those devices be 100M?:confused:
mrSHEiK124
11,488
Class 2 is 10M, Class 1 is 100M
