I am running a 3.6 p4 and am seeing it heat up again.
Idle=36-40c and Load=~66c but has gone higher.
Sonata Case with a 120mm fan cut into the side. Zalman 7700cu Heatsink & AS5.
I have 1 120mm fan in the front and another in the back. The one in the front doesn't seem to be bringing in much air. The back fan is moving air out well. If I put the door on the temp goes up to 70c in about 1/2hr of gaming. Going to reapply AS5 and see what happends. Thinking of getting 2 better fans for the side and front. What CFM should I look for?
Any other ideas?
Thanks
Any other ideas?
Thanks
