When you open a new ream, just make two equal stacks; you should be able to get very close. Recycled paper will generally leave more debris in your printer over time. You probably won't notice the difference between 92 and 94 unless you compare them side by side. Aside from this, I just shop for price.
Yesterday I bought two boxes of paper on sale at Office Depot, 5 reams each. The brand is "Double A" and it's made in Thailand "from farmed trees" and they have stuff on the box extolling their growing methods as being ecologically sound and conscientious, for what it's worth (maybe not much, I don't know).
It's 94 brightness, but what caught my eye right at checkout was that it's 22 lb. I didn't expect that. The ad in the paper didn't mention that, I just assumed it would be 20 lb. like they always are, at least I thought they always are. I have some 24 lb. paper from way back, paid more for it IIRC, and I thought that the heavier papers were generally thicker and more expensive. Why would they have a 22 lb. paper on sale like that ($11.99 for 5 reams, limit 2 boxes/customer)?
I'm wondering if 22 lb. is really a good idea. Won't this mean that I won't really get 250 sheets in my HP4 tray? IOW, wouldn't it be thicker than the 20 lb. paper I've been using? BTW, I've been having very good luck with the 10 ream box I have almost finished off, not many skipped sheets, very very few. It's Georgia Pacific and only 88 brightness, I just noticed, a multipurpose paper.
Paper designed for laser printers or Xerox copiers is the right stuff. Do NOT use paper for inkjets.
The boxes don't say a word about what the paper is for! There's a very small set of graphics that evidently suggest that it's multipurpose, i.e. symbols that I presume are for laser, inkjet, copy, fax, and some other machine.
But all laser and Xerographic technology printers do terrible things to paper! This from someone who worked for decades in the paper business. So the paper has to be made to "stand up" to that and still perform. Dust generation inside the printer is a factor, but usually a small one. Image sharpness can suffer on poor papers - either ragged edges or missing white spots in black areas. Curl of the paper sheet is the more likely source of trouble. So, I suggest two things:
1. Note which way the paper is placed in the feed tray. That is, look at the wrapped ream - with the wrapping seam up or down when you open the wrap and place the paper in the tray - and print several copies. Now remove the paper from the feed tray and turn it over, then print several more copies. Whichever way makes the finished copies come out flatter, do it that way all the time.
Great idea!
NOTE that, if you switch to another paper supply, you'll have to re-do this experiment. Also note in a HP4 that the upper feed slot for custom sheets feeds in the OPPOSITE way - feeding from the bottom tray turns the paper over right at the beginning, but not when fed from the upper slot.
2. If necessary, experiment by buying one ream each of several brands of paper and trying the "feed side up" test above. Decide which paper gives you the best (least curled) final product. Then stick with that brand - most paper mills don't change much about how they make their papers. So what works will continue to do so, and what malfunctions probably will not get any better.
The ultimate test is when you make two-sided copies. An HP4M won't do that by itself, but you may have occasion to do it by manually re-loading printed-one-side paper back in to print the second side. This is when the paper curl factor becomes even more important, and a little less predictable.
It's because of occasional skipped sheets when refeeding paper to achieve both-sides printing that I've long abandoned using the bottom tray for this and I now always manually feed for the 2nd side. I don't recall having repetitive problems when manually feeding paper but one time a tiny piece tore off from the corner of one sheet and I had to first find the piece and then manage to remove it, a pretty tricky affair.
I haven't opened either box of the
Double A brand, 5-ream, multipurpose, 94 brightness, 22 lb. (
! ), "farmed tree," made in Thailand paper I just bought at Office Depot. Is this stuff likely to be OK?
