acidvoodoo
Originally posted by: GRagland
I have to make a mock math test for my math class. If someone could double check the answers to some of the problems that im gonna put on it then that would be much appreciated.
- Solve the triange with the measures: A= 31 degrees, a=16 inches, b=23 inches. Find B, C, and c. (btw, a is the side opposite the angle A, etc...)
I got 132.2 degress for B, 16.8 degress for C, and 9 inches for c. Is this right?
Yes, but you could also have 47.8 degrees for B, 101.2 degrees for C, and 30.5 inches for c.
B cant be 47.8, because there is a picture and its a more then 90 degree angle. so i subtracted 47.8 from 180 which equals 132.2 degrees. is that alright to do?
does it say the drawing is accurate?
and how can you do that, because you are only told one angle in the first place
