PreCal math problems, I need someone to double check. (Will pay money!)
GRagland
677
!!!anyone know de moivres theorem ( it deals with complex numbers)? please PM if you do and would be willing to help me for a minute. I will pay you! (paypal)!!!
OK, so that problem is done.
Heres another! I think i did it right:
1. Let vector v= (6, -2). If PQ (vector) is a representation of that vector and Q is located at (10,5), then where is P?
- I got P is at (4,7)
Is this right?
2. A 5-Mile straight of I-90 at the columbia basin has a 3% downhill grade. A semi truck weighing 20 tons is parked on the road. what is the force that that tends to make the truck roll downhill?
MikeMike
45,885
66
sohcahtoa
remember that, and it will work
sin= o/h
cos= a/h
tan=o/a
i believe i am right there am i not?
MIKE
isekkii pythagorean theorom = RIGHT triangles ONLY
and yeah this is from trig, not precalc
GRagland
677
Originally posted by: nourdmrolNMT1
sohcahtoa
sin= o/h
cos= a/h
tan=o/a
MIKE
this is not a right angle so there is no hypotenuse. you have to use a different equation.
i just need someone to quickly double check the answer, thats all, i dont need help on how to do the problem.
MikeMike
45,885
66
there is ALWAYS a hypotenuse, the hypotenuse is the side that is opposite the largest angle, or has the longest length, dont know where you learned your math
jimmyhaha
2,851
I have to make a mock math test for my math class. If someone could double check the answers to some of the problems that im gonna put on it then that would be much appreciated.
AgentEL
1,327
i'm scared of what they are teaching in schools these days...
GRagland
677
i know how to do the problem, but thanks, i just want someone to double check it real quick, just in case im making a stupid mistake or something.
Yossarian
18,010
you are wrong.
MikeMike
45,885
66
d00d, im only 16, i learned that a LONG time ago ,,,,
how am i wrong pip?
AgentEL
1,327
how am i wrong pip?
i'm not pip, but it's just by definition of what a hypotenuse is. The side of a right triangle opposite of the right angle.
acidvoodoo
2,972
hypotenuse does not play a part in this question
you need to use the sine rule. a/SinA=b/SinB=c/SinC
as he wants to check his answer, i'm workin it out now, but it's like 11:20 here so i'm slow lol
jacob0401
2,185
ok I checked it and it works.
first cosine law to get c side.
then cosine law again to get beta and gamma angles.
one note you might not want to round early on.
Krakerjak
767
- Solve the triange with the measures: A= 31 degrees, a=16 inches, b=23 inches. Find B, C, and c. (btw, a is the side opposite the angle A, etc...)
I got 132.2 degress for B, 16.8 degress for C, and 9 inches for c. Is this right?
Yes, but you could also have 47.8 degrees for B, 101.2 degrees for C, and 30.5 inches for c.
acidvoodoo
2,972
is there a picuture with the question? i need to know if the 2 sides you are given are enclosing the angle so i can draw it, makin it easier to work out
jacob0401
2,185
This is right becuse when u solve for c side you use a quadratic equation (c^2-34.4297+273=0) and there are two solutions for side c. one is 8.95 as the original poster stated and wanted us to check and the other is 30.5.
AgentEL
1,327
I think he is following the standard convention that the capital letter stands for the angle and the lowercase stands for the side opposite of it. There is an angle "A" and side "a" is the leg opposite of it. Same goes for B and C. You should be able to construct a picture out of the information already given.
GRagland
677
B cant be 47.8, because there is a picture and its a more then 90 degree angle. so i subtracted 47.8 from 180 which equals 132.2 degrees. is that alright to do?
