Powerline Wireless Range Extenders
mdcrab
I have a preference towards Netgear, but am currently using a LinkSys WRT54G. The software interface that Netgear uses is considerably better. Anyway I like the transmission power setting available on the LinkSys to extend the range, but I am thinking about going back tio the Netgear Router WGR614v4 and using a:
WGXB102
Has anyone here have any experience with these units? They are a little pricey, but since they are new maybe the price will come down.
mdcrab
Interesting product never saw it before.
It is replacing a CAT5e with HPNA and putting an Access Point at the end.
The HPNA part is based on the Netgear, XE102 which is a low speed device, as a result it does not really take advantage of the 802.11g capacity.
Actually you can probably achieve more flexibility by buying two XE102 and a Cable/DSL Router of your choice.
Is it better than 802.11g extender?
I would guess that it depends on the environment. While the WGXB102 would provide stable 6-7Mb/sec. (number taken from the link bellow), an 802.11g Extender might provide more or less than 6-7 Mb/sec (depending on the specific envioroment).
One thing is sure it would more stable than an Extender.
CNET review - http://reviews.cnet.com/Netgear_WGXB102...extender_kit/4505-3304_7-31119874.html
:sun:
P.S. Take into consideration that the above is a theoretical analysis since I never tried the product.
