So what's this talk about max. +4 bins for a 3770? The base multi for 3770 is 34x. How come you're at 43x?
Ok, so I got a good offer through existing avenues, so I have blown my budget up... and looked at the following:
Antec Three Hundred Black Steel $60
CORSAIR Enthusiast Series TX650 V2 $80
Intel i7 3770 $305
ASUS P8Z77-V DELUXE $275
CORSAIR Vengeance LP 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 $86
WD Black 500GB (x2) $135
Samsung 830 Series 128GB $90
LG Black - WH14NS40 $70
Geforce GTX680 $500
This comes to about $1600.
I have a monitor and keyboard and mouse that I will use.
Unless you really -need- the very specific extra features (20+1 phase power delivery, PLX8608 PCIe 2.0 "splitter") on the Deluxe, I would go with the P8Z77-V Pro or even the P8Z77-V LK(Do not confuse with the LX version). This board is only a 4+1 phase design, so don't expect overclocking. That should save you some cash.
Also, might I ask at what resolution you plan to game?. the GTX680 seems a little "overkill" for 1080p, you might be better of with a cheaper GTX670 or 660ti...
Other then that, I can't really fault anything...()![]()
No, you are perfectly correct. The -highest- multiplier available is 38x. The "trick" is ASUS's multicore enhancement. This unlocks the turbo multipliers to be used like the regular ones, which nets you 4+5 bins...
Is this available on all Asus Z77 boards? I can't seem to find the info on Asus' site.
Forget the Xeon? Why! You just lose a little bit of speed and no iGPU but he doesn't need it when he gets a GPU
Intel i7 3770 $305
Geforce GTX680 $500
This is is a pretty bad build IMHO. You can get nearly double the gaming performance for about the same amount of money. Here's how:
- Case: Good
- PSU: Switch to one with 4x PCIe power connectors like the XFX Core 650W for +$10 AR
- CPU: Switch to a Xeon E3-1230 V2 for -$71
- Mobo: Switch to something reasonable like the ASRock Z77 Extreme4 for -$160
- RAM: Can shave off a little here by going with this G.Skill DDR3 1333 16GB kit for -$20
- HDD : Can get double the capacity for only a little more with the 7K1000.C +$5
- SSD : Good
- ODD : OK if you need Blu-Ray, but take advantage of the promo to get this for -$13
- GPU: And the piece de resistance, get GTX 670 SLI for +$280 AR
Total price difference: +$21.
Now, do you need this amount of power for 1080p gaming? Probably not. This is illustrative of what you can get by spending where it matters and saving where it doesn't.
Thank you all for your input. I have some serious things to consider.
Let us know what decision you come to.(Preferably before you commit.)
Absolutely, I am thinking about:
XFX Core Edition PRO650W
Intel i7 3770K
ASRock Z77 Extreme4
Hitachi GST Deskstar 7K1000.C 0F10383
Seagate Barracuda 3TB 7200RPM
LG Black - WH14NS40
GTX670 - x2 (SLI)
I will go with one GTX670 for now and get another when I can get a good deal on it.
Intel i7 3770K
ASRock Z77 Extreme4
LG Black - WH14NS40
GTX670 - x2 (SLI)
That seems resonable for the most part, though I would recommend either getting SLI right off the bat or skipping the capability altogether. Also, you seemed to be leaning towards stock speeds, but you swapped the less expensive Xeon for the overclocking-capable i7 3770K, why is that?
Niiiiiice system! Some reassurance for you. My gaming box:
Asrock P67 Extreme4
i5 2500k at stock 3.3GHz
8GB of RAM
Single Gigabyte GTX670; it has a stock 10% (roughly) overclock
Samsung 470 SSD (OS/apps)
Seagate Momentus XT500 (Games)
Corsair HX1000 PS
I game at 19x12 with all the eye candy turned way up and haven't found a game yet that isn't smooth as glass, no hiccups, etc. Your new system as spec'd will also edit HD video very well. For video editing purposes, the only thing I'd add is another HD. Keep all video off the system drive, and have the "read the video" and the "write the encoded video" drives separate if possible. Honestly, another 2TB HD will set you back another $100; it's worth it.
The AT community really took interest in your build; this really is the best place on the internet for this type of advice and the community came through for you. Consider yourself blessed and go with it. ()![]()
Doing some reading it seems like the 3770k will have an advantage when it comes to video encoding and such. I am thinking about over clocking down the road, will get some better cooling at that point.
Thanks for the tip on the SLI, why do you say get it now or skip it?
