GeezerMan
OK, I'm thinking of mounting some internal drives into my Antec P150 case since it has the room. I just like the idea of having internal storage. I'm also thinking of putting power switches on them since I might not need to access the data very often, and why keep them running if I don't need access. I might even use them for image backups as well. Yes, I know I could also use external drives, or set up a raid. Any pros or cons to putting a power switch on a drive and keeping the data cable connected? The P150 case has plenty of holes on the back, and a small little toggle switch could easily be installed. If windows is running, is it possible to turn on a drive? I know external drives are recognized when turned on, but they are connected via USB and not directly like these would be. I know the drive letters would have to be different. Thanks
