!! power supply !!
yy3d
I m using EP-8K7A motherboard. I plan to buy a new power for my system. Anyone know which Power supply is good for this motherboard? Also what different between Antec's turepower series and Solution Series? Thanks!!
The True power series is better or should be better than the Solution series. However, I suggest you look into one of those Vantec Steath PSUs, expensive but excellent and highly reliable. Other than that, the Antecs should do well for you and the Solution series should be good enough if you aren't overclocking a lot.
