Power supply question.
Sep 16, 2004
86
I have an old HP with a 100 watt PS. Can I use a larger PS? I can't seem to find any 100w PS's. Any help greatly appreciated.
jackschmittusa
5,972
The system will only draw what power it needs, regardless of the rating of the psu. If the rig draws 90w of power, it will pull the same 90w from a 100w psu or a 500w psu.
Blain
Do a Google search for the PS you now have in your case and you should get tons of links to vendors selling higher wattage units that will fit.
Search for the PS brand name... wattage... and the model number of your HP.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
Is it an ATX powersupply? It might be a little tough finding one if it's an older AT powersupply.
Blain
A friend of mine has an old HP (8575C), that has a full size ATX MB but only a micro-ATX PS.
