Would anybody here know why a PC would bootup ( power on ) by just turning on the power supply switch ?
I just put back together my system after getting a DDR based Athlon board and ram and the only thing that was a problem is this powering up of the PC simply buy turning on the switch on the power supply. If I go to shutdown in Windows it'll shut down fine. But then if I switch the power supply switch to the off position then a moment later switch it back to the on position the PC will bootup.
Any ideas or has this happened to you ?
Fixes ? Did I overlook somthing ?
Thanks for any info.
