Of note this is a completely new system. The power supply fan will not work above 1800 rpms causing my ASUS CUSL2-C motherboard to overheat. The Hardware Monitor program of BIOS indicates this as a problem when I go into Setup. How can I be sure that the reading of both the fan's speed and the corresponding high MB temperature are not false positive? Any other symptoms I should look for? Is the motherboard's voltage regulator also a factor I should consider? A detailed response would be appreciated.(By the way I am not overclocking my Pentium III 800EB-FCPGA processor.)
