Power Supply Calculator
lehtv
11,897
74
What for? There are plenty of PSU calculators out there that are not stickied. I don't see how this Asus calculator is any better, in fact it seems to have fewer options than Thermaltake's calculator, for instance. It seems to overestimate the needed wattage to compensate for bad quality units, just like all the other calculators.
Also, wattage isn't everything. What's more important is the amount of amps on the +12V rail(s), the number of connectors needed for your graphics card, and the quality and reliability of the unit.
dma0991
2,723
The PSU calculator is slightly flawed. I matched the my specs and the calculator churns out a 400W requirement. Definitely could do with less but I find it fair as most PSUs that I purchase is a minimum of 500W. What's flawed is when I add in a single HD7970 and the wattage shoots up to 700W. You certainly do not need that much for a HD7970, realistically 550-600W is plenty.
The hilarious part is that the calculator allows me to account for two Core i5 3570Ks. I'd wish. :biggrin:
GeeKayCee
The Asus one is one of the worst ones, for certain. Gave a system that runs fine on 520W PSU an 800W as recommended, instead. Hmm, come comes? Aha... Asus makes PSU as well. Make your conclusions, gentelmen.
mikeymikec
21,630
16,908
PSU calculators (all the ones I've seen) are fatally flawed. The only way of making them vaguely accurate would be to make a short list of decent PSUs / brands of PSU and run the tests using those, and have a disclaimer of "if you're not using a PSU on this list, you may as well be using a ouija board to calculate the answer to your question".
Durvelle27
4,102
XD said my pc requires 700W when it doesn't even break 600W barely 550W
LongN3ck
20
fair points. perhaps a list of all the calculators, since a majority of posts here seem to be about needed wattage. ;)
lehtv
11,897
74
None of the calculators are useful enough to be stickied. All of them estimate (or should I say overestimate) the PSU wattage, none of them calculate actual peak power consumption. Perhaps instead there should be a sticky with information about how to judge how much power your system uses, how to decide the PSU wattage needed, and whether a particular PSU is worth buying or not.
Phynaz
10,140
819
Lol, that calculator added 200 watts for an HD7850 card, which is a 105w card.
It says I need a 550w supply for my system, which draws 200w from the wall when fully loaded.
bononos
3,945
193
An i3/i5 pc with a 7850 won't take more than 200-220W peak while gaming, (more in furmark). The online calculators overestimate the power requirements alot.
Vectronic
489
ASUS: 400W
Thermaltake: 356W
Actual PSU: 750W
Peak usage: about 270W (hypothetical since I actually haven't measured)
Result: power usage calculators fail, but are accurate enough in my case, re-confirmed my over-powered PSU. (cheap, matched color scheme, don't care)
Edit: MSI's calculator is pretty close (assuming "stock").
Power-On's isn't... though it doesn't have my CPU/GPU either, but it's way off.
