Here's the latest & greatest...Originally posted by: silverdj
What should I be looking for in a good power supply?
I know that the only way I'd give mine up is if I went to a GPU that demanded higher numbers amperage wise, otherwise you'll get my X-Pro from me if you pry it from my cold, dead hands.
Good overall wattage, high efficiency, lots of amps on the 12V rail, and a reliable brand name with a good reputation.
Originally posted by: Zepper
I look for a brand name with a record of reliability. Then it has to be appropriate for the system in which it will find itself (power capacity, cable lengths, etc.). After that, I prefer single +12V rail over split rails. I also like to have active Power Factor Correction, and autoranging AC tolerance. Helps make your system relatively immune to line-side garbage and they usually come hand in hand. After that, reasonably low noise is good, but I'm not a Noise Nazi - if it is too noisy for me it is generally not hard to fix within my tolerance. And finally, high efficiency is good once the other bases are covered - the 80+ label denotes high efficiency. For the great majority of systems, the Enhance ENP-5140GH or 5150 will cover all those bases and leave some $$$s in your pocket.
.bh.
Cheap too!
Heh! Jonny Guru's creaming himself, too...
Cheap too!
Holy crap! I thought Ultra PSUs were teh sux0rs!
Cheap too!
Originally posted by: RallyMaster
aww shucks. my case is way too big for that PSU then....got any other ideas? (I'm going to buy it from Fry's because I have a 30 dollar gift certificate that I want to use....and it has to be B&M).
I'm definitely going to use sleeved cabling since I have a windowed case and I want >80% efficiency....
Heh!
You 'guys' need to stay with the times...
A month ago it was Zalman, with their heatpipe PSU -- this month it's Ultra, resurrected...
Next month, maybe its' Silverstone's turn, again, but I doubt it!![]()
Heh!
You are once again exactly correct!!:thumbsup:
I`m still trying to figure out who the "WE" are...most likely him and the mouse in his pocket...hehee...
Heh!
You ARE 52 years old and post like this? What a wasted life
You and Vin are very obvious flame baiters
Have a nice day!!!!!!!!!!
EDIT: Be sure and copy / paste this post as you have all others, then send it with your "I'm misunderstood" tears to the Mods.
Cheap too!
Reviewed by: madmat on 2006-12-13 07:23:14
Author: madmat
Heh!
