You'll be hard pressed to find a good quality PSU for $30 or under.
Here is a decent one from Raidmax : 400 Watt P4 Power Supply w/dual Tri-LED Fans
There are others with probably higher so called wattage but they will usually be very cheaply made and not worth buying in the long run.
Raidmax,Enermax,Zalman,Antec,TTGI,Sparkle,Forton and PC Power and Cooling are some of the best names in the industry, the latter being the king of all PSU's period but at a price !
