Hello,
Does PC notebooks support the Auto-Dim feature like the Powerbooks? Vs just turning off the screen. If so, how do I enable it, or what software?
Auto-dim, auto adjust the brightness when idel, dim to lamp to save power.
Also, is there anyway to further under clock Max Battery? Like so it will go lower than 600mhz.. like 300-400mhz or so. Software? I don't need 600mhz when proc words 😛
Thanks
Thanks
