- Aug 27, 2004
- 1,717
- 0
- 0
Update: Since posting the info below, I removed everything except for the powersupply, and the motherboard, and it would not come on. I removed the network cable, and it turned on just fine. Since my motherboard has 2 network connections, I disabled the one, and was using the other. Everything was fine. Now, the situation is back. It will not turn on, no sounds, nothing. Same issue as described below. I am beginning to think my machine is possessed!
My computer will not turn on. No beeps or sounds of any kind, no lights, nothing... dead.
A little history. I recently changed out the motherboard and video card. When I put it back together, I could not get it to turn on. Same issue as described above. Then, for some reason it turned on. I set up my Raid drives, loaded XP Pro, updated drivers, etc. It rebooted during the install and the driver updating just fine. No problems. Next day, I could not get it to turn on.
I have tested the power supply with a tester, all green lights. I have replaced the power switch on my case. I have even bought a new, same model, motherboard. I installed the new motherboard tonight, and the same exact thing happened. It would not turn on, then for some reason, it started. I turned it off for a while, and when I went to turn it back on, nothing, just like before.
Power supply - Antec NeoPower 480
Motherboard - MSI K8N Platinum 2
CPU - 3200+ Winchester
Ram - 2 gigs, 4 x 512 3200
Video - ATI X800Pro
Hard Drives - 2 each WD Raptors 36 gigs
Optical Drives - 2 each Nec 16X DVD-RW
I know it has to be something really stupid, but I cannot figure it out. Any help would be greatly appreciated.
Video - ATI X800Pro
