Power ISA going open
soresu
4,214
3,688
Apparently the Power ISA just went open, given its a bit more active than MIPS with IBM still pushing new POWERx CPU's, there may be some mileage in this given its mature status.
moinmoin
5,248
8,463
What makes the Power platform interesting is that with this step it's fully open source, including BIOS and hardware. That a unique quality for such a mature platform. It's unfortunate it's essentially non-existing in consumer space these days, which may make this a case of "too little too late".
zir_blazer
1,265
586
Well, there is the Talos 2. But it cost more than x86 for the same performance, plus you can't expect to run Windows on it. The only people that can successfully use that platform are Linux power users.
gdansk
4,691
7,931
I think it is too late. A similar effort didn't save SPARC, though I suppose it helped keep it alive in Japan. Power isn't dead, won't die soon, but being open isn't going to increase the number of implementations.
soresu
4,214
3,688
Not necessarily true, China has been all over the map on ISA of natively designed CPU cores - at least Alpha (Shunwei), MIPS (Loongson) and ARM (Phytium).
It would not surprise me to see this spur them to action for POWER too, especially if the pre-existing software base is worth it.
Also SPARC never really penetrated beyond the server space if I'm not mistaken, while POWER was in 3 generations of Nintendo consoles, and 1 each of Sony and MS respectively, that's well over a decade of consumer hardware optimised to death, even if far from the latest version of the ISA.
Given its new open status, we might see Nintendo fabbing a new small POWER cpu at 8nm or something to cover the classics of Gamecube onwards.
soresu
4,214
3,688
There's no reason that the same setup used for Windows on ARM can't be ported to other ISA's like POWER and RISC-V.
I think I heard they had ported it to EDGE already, not a surprise given MS Research has published papers on the E2 uArch based on it.
DrMrLordX
23,140
13,234
Okay, what am I missing? I thought POWER went open in 2013? All they did was join the Linux Foundation last week . . . it changes their governance but um, not sure what else that really means?
moinmoin
5,248
8,463
It's now royalty free.
nicalandia
3,331
5,282
The Only reason the Dreaded "Power ISA" was not entirely forgotten long ago is because it has been backed by IBM one of the huge corporation that still standing for more than a century, but just like the OpenSPARC, nobody really cares about it.
DrMrLordX
23,140
13,234
Okay, thanks. That wasn't immediately obvious from the press release I read. Either that or I just skimmed too much.
POWER9 found its way into Summit. It's interesting(ish), and had both AMD and Intel flubbed starting in 2017, POWER might have made sort of a comeback in some parts of the server room. But you know. That's not entirely what happened.
yours02
Banned
Dec 14, 2019
14
Hello guys, do any of you have experience with POWER 7+? and they weird CPU vs cores meaning?
DrMrLordX
23,140
13,234
Ugh, don't remind me of that - still stinging from Nintendo misleading us into thinking that the WiiU CPU was POWER7 with that WATSON comment.
Nintendo hasn't done anything close to cutting-edge with their CPUS since . . . eh . . . erm . . . well it's been awhile.
Reactions: soresu
soresu
4,214
3,688
Probably the initial Gekko chip which was a customised variant of PowerPC 750CX, more or less state of the art at the time the GameCube came out.
Everything after that was either the same thing higher clocked (Wii), higher clocked with more cores (WiiU), or an off the shelf SoC using standard ARM cores repurposed from a 2 year old product of the SoC's designer (Switch).
It would be nice to see Nintendo really taking a swing at serious gaming for once in the last 15-20 years.
Maybe their decision to allow more 'hardcore' games on the Switch could be them testing the waters to that end - it would certainly be interesting to see a Switch using state of the art CPU and GPU uArch on a state of the art chip process, or at least a 7nm variant.
DrMrLordX
23,140
13,234
Sounds about right. N64 had a pretty interesting set of hardware as well. Everything after the GameCube though? Meh.
Reactions: soresu
