May be only available in certain Fry's stores. Maybe brianv can elaborate on where this deal was found...is this on the ad? or still on sale? I called and they said $14
Originally posted by: HalfHitch
volts X amps = watts
For $9, go for it. If it won't run the laptop, it will at least charge the battery.
Originally posted by: JameyF
Originally posted by: finalpendragon
150 kinda sucks. I would go for 250 with 450 peak. Or if you want something powerful, you can usually find a 450 for about $25-30.
Yea, but you'll have to watch out for blowing fuses going through a cigarette lighter with a 450 watt inverter. I don't even think it would be possible to sustain that much that way. I would run a dedicated power line directly to the inverter if you're going to get somethign that strong.
Originally posted by: Calgar99
150 watts is rated as peak power. Normally continuous power is about 1/3 of that rating, so it should run anything around 50 watts. Most laptops run around 35-50 watts, but that doesn't include what the power adapter uses itself... so you're cutting it close.
It may work until you try to do something with a lot of power (i.e. spin a DVD) and then it may trip the inverter's overload circuit.
Your best bet is to get a bigger power inverter... or get the DC adapter for your laptop.
-Matt
Originally posted by: ableach33
I have a 300 watt inverter in my car.. i've noticed that sometimes with bumps or if i touch the cord, the power will just shut off.. also, i have a cable from my headphone out to the aux inputs on my cd player and have line noise, but sometimes it will be very clear... anyone know why this might be? anyone know where else I might want to post this?
