VirtualLarry
I used to use a Q9300 @ 3.0, and a GTX460 1GB.
Then I upgraded to a Phenom II X6 1045T @ 3.51, and dual GTX460 1GB cards in SLI.
But power consumption was too high.
So I swapped to my low-power E-350 (Zacate, 1.6Ghz dual-core) mini-ITX rig for a while.
Even under full DC load, on both cores and the IGP's SPs, power consumption was 47W according to a KAW. Not bad.
But listening to internet radio, and web browsing, was painful. The internet radio would skip every once in a while, and web page scrolling was just laggy and bad, with the DC running in the background. Clearly, that rig was underpowered for what I wanted to use it for.
So I'm back to my Q9300 @ 3.0 and a single GTX460.
Idle power consumption is 94-140W, browsing web pages.
Load power consumption (full CPU DC load) is 145W.
Load power consumption (full CPU and GPU DC load) is 230-250W.
While this amount of power isn't horrible, is it possible I could do better?
I guess if I were truely interested in just web browsing, and was willing to cut out the DC, I could let Win7 put the system into S3 sleep mode, which draws 5W, when I'm not using it.
I realize that idle power consumption isn't great, for C2D/C2Q-era chips, due to lack of power-gating.
But I recall seeing some charts showing that C2D is actually MORE power-efficient at load than newer chips.
So I'm hesitant to upgrade, if there's nothing really better at load.
AMD CPUs seem to actually be worse as far as power-consumption at load. (At least, Phenom II X6 and BD FX CPUs are. I don't know about LLano.)
What say you, forum?
Edit: If I were to upgrade, this is what I'm looking at:
ASRock B75M-ITX LGA 1155 Intel B75 HDMI SATA 6Gb/s USB 3.0 Mini ITX Intel Motherboard
http://www.newegg.com/Product/Produc...82E16813157310
Intel Core i5-3450S Ivy Bridge 2.8GHz (3.5GHz Turbo) LGA 1155 65W Quad-Core Desktop Processor Intel HD Graphics 2500 BX80637I53450S
http://www.newegg.com/Product/Produc...82E16819116507
The only downside is, it seems like most of the mini-ITX S1155 boards, only have two RAM slots. But this one has a single SATA6G port for my primary SSD (already own a 240GB SATA6G SSD), and it has front-panel USB3.0, which is nice.
Edit: I looked at the mobo manual, B75 chipset apparently doesn't support RAID. I was hoping for a little RAID-1 (mirroring) action, so I could have an SSD in the SATA6G port, and then a Blu-Ray burner, and two 1TB HDs in RAID-1 for my data. Does anyone know if you can set up a software RAID-1 under Win7, or is that limited to server OSes?
I would need a decent, small, mini-ITX case, with front-panel USB3.0 too. Perhaps one of the Lian-Li aluminum cubes.
Would I gain any performance, going from a 3.0Ghz C2Q, to a 2.8Ghz IB? To me, it seems like a wash. If I keep my GTX460 in there, then load power consumption is only going to be, maybe 35W better than my current rig. (From a 95W CPU to a 65W CPU.) Which seems like it wouldn't be worth it at all.
Plus, I would want to upgrade to Haswell when it comes out, due to AVX2 support, for my distributed-computing tasks. (Which might allow me to get rid of the discrete video card.)
Edit: This case looks good.
LIAN LI PC-Q08A Silver Aluminum Mini-ITX Tower Computer Case
http://www.newegg.com/Product/Produc...82E16811112266
Need to get an adapter cable to connect the USB3.0 cables on the Lian-Li.
http://www.amazon.com/Silverstone-Te.../dp/B005NGGKPU
Edit: Why not go for Blu-Ray and M-disc.
LG Black 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 10X BD-ROM 4MB Cache SATA 12X Super Multi Blue with 3D Playback & M-DISC Support WH12LS39 LightScribe Support - OEM
http://www.newegg.com/Product/Produc...82E16827136241
SeaSonic M12II 520 Bronze 520W ATX12V v2.3 / EPS 12V v2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151093
