Pghpooh
HI
I just got 4 Panaflo 92mm fans that were untailed. I want to put connectors on the fan leads. I prefer to make custom length leads for each fan in order to keep the inside of the case as neat as possible. One way to do this is to buy a few Y-connectors and just cut them and splice the connectors from the Y-connectors to the fan leads. Another way is to buy the pin connectors both male and female sockets and custom make them. The only problem is,, I can't remember the name of the connector used for the power leads or used to make the Y-connectors. The name of "Molex" comes to mind now.
Are there any sites out there that have the connectors I can use??
Thanks
Pghpooh
Thanks
Pghpooh
