Originally posted by: fredtam
On your thermostat turn it to "fan" instead of auto and see if the air handler comes on.
heh, true...that would make sure the blower has power.
Yeah, I get no lights or anything at all 🙂Originally posted by: spidey07
Modern?Originally posted by: fredtam
Originally posted by: oldsmoboat
Is part of the unit, (heater/air handler) located some where else like the garage?
If so, the fuse is in that unit.
In most modern units there is not a fuse on the air handler. There is a fan on switch. Usually the breaker is in the main box and it is labeled as furnace.
http://www.handymanusa.com
My unit is 8 years old and it has one.
Pink, ATC fuseOriginally posted by: fredtam
Where is there a fuse and what brand? Do you mean breaker?
Originally posted by: ICXRa
Every unit I have ever seen has them. If they didn't and a spike got thru the breaker it would risk blowing the contact board a be very expensive to repair as opposed to a $2.50 fuse. I can't find a picture of showing the electrical installation after several google attemps and obviously and I not describing it very well. Perhaps Evadman will see this a chime in!
Skoorb wants to know if him taking a picture of the disconnect would be of any use to you...
It looks to be on but to be sure it hasn't tripped...Originally posted by: Skoorb
outside.JPG <- that's outside, with my switch.
Thermo says to cool. Heat pump does not do a single thing when set to hot or cold; absolutely no lights or indication of life, period.
Ah, my DC panel is the same. I have no visible disconnect - or anything like your setup anyway - anywhere.Originally posted by: oldsmoboat
My fuse is behind this panel
Heat Pump and Spa disconnects
Heat Pump DC panel open
Air Handler
Done about 10 times 🙂It looks to be on but to be sure it hasn't tripped...
turn it off then back on.
Did you do the same for the breaker in your main panel?Originally posted by: Skoorb
Air HandlerDone about 10 times 🙂It looks to be on but to be sure it hasn't tripped...
yep!Originally posted by: oldsmoboat
I can't turn the fan on. Normally there are lights on the thermo. Tonight, none. Normally fan turns. Tonight, nope.even if you turn the fan on?
yep!Originally posted by: Skoorb
Battery in thermo?Originally posted by: oldsmoboat
yep!Originally posted by: SkoorbI can't turn the fan on. Normally there are lights on the thermo. Tonight, none. Normally fan turns. Tonight, nope.even if you turn the fan on?
