openwheelformula1
- Sep 2, 2005
- 727
- 0
- 0
Interesting! I would have no problem going with a different chipset except I'm not sure if there are any PCI-E cards for that chip. I need PCI-E.Originally posted by: xtknight
Samsung SIR-T451 ATSC 8VSB Terrestrial/QAM HDTV Tuner [VGA out to VP930b] (it's screaming now to be let out of its cage and hooked up to a NEC 20WMGX2 widescreen via YPbPr)
ATI TV Wonder USB 2.0 (Theater 2xx) [coax,S-Video,component]
As for capture programs:
ATI MultiMedia Center (annoying, I can't disable TV-on-demand)
I was also working on one of my own TV capture programs in C++ that was going well. Since ATI MMC is slow now (can't disable TV-on-demand), I may continue it.
SageTV and BeyondTV both lack support for my card (the last versions I tried). GB-PVR also lacks support but I got it to sort of work by editing config files (but not consistently).
I just want something simple I can watch+capture TV with and schedule something once in a blue moon, I don't need/want all the other stuff. So I have been using ATI MMC. But they have neutered that with mandatory TV-on-demand so I don't know what I'll do now. The USB doesn't bother me at all. It's nice to have less EMI with the tuner in a separate box and the ability to hook it up to a notebook.
For maximum TV tuner quality I would be going with a tuner based off the Conexant Fusion 878A chipset.
ATI Theatre 550 Pro vs. Conexant Fusion 878A/typical chipsets found in capture cards
Round 2: ATI Theatre 550 Pro vs. Conexant Fusion 878A/see how they fair against eachother in NOISE FILTERING CAPABILITY
I don't need any HD tuning capabilities. There is a PowerColor Theater 550 Pro-based PCI-E card. That may be my only option.Originally posted by: xtknight
Sadly, at this point I'm not sure there are any PCI-E tuners except for a couple DVB-T (European HDTV) ones.Do you want an analog TV tuner or one that can also handle HDTV? (I haven't seen one HDTV tuner that can't also handle analog.) If HDTV, what country are you located in? You will need to get a card that supports your HDTV standard. As for analog I think by now they all support NTSC/PAL/SECAM anyway.
So you're also searching for a PCI-E Theater 550 Pro-based card. The only one I've really found is a PowerColor, and it's only on a couple sites I don't normally shop at, like eWiz and Directron. Where are you getting yours?Originally posted by: tomt4535
Ive got 3 tuners in my htpc. The first one is a PVR-250, second a Visiontek theater 550 card, and third an Avermedia A180. All three work together well in Media Center 2005. Im upgrading my motherboard this week, and its going to be a microATX board, so Im going to pick up a PCI-E version of a theater 550 card. I like Media Center's interface, Although it is difficult with drivers and such. Once you get it set up, it wont bother you, its just a pain in the arse to get it there. I hear good things about GBPVR, although I havent tried it.
