Spikesoldier
- Oct 15, 2001
- 6,766
- 0
- 0
Kerr, S. (1997). Ultimate Rewards : What Really Motivates People to Achieve. Harvard Business School Press. Retrieved from EBSCOhost.
citing a paper
citing a paper
I think you made an error in linking. Substituting the ID characters into a standard video URL gives me something about a pharmacy scandal or something. Your link as it is gave me "Pinkie Pie - AHHHH", ""Trixie's Magic" - Original 8-bit MLP theme", "Girls' Generation ????_THE BOYS_Music Video (KOR ver.)", and "DJ DODGER STADIUM - STADIUM STATUS".
(optimum environment is 5-7% O*2 and 5-10% CO2, at 42°C, for 3 days on HBA)
What bacterium is this?[FONT="]
[/FONT]
int ledPin = 12; // choose the pin for the LED
int ledPin2 = 11; // choose the pin for the LED
int inputPin = 2; // choose the input pin
int inputPin2 = 3; // choose the input pin
int val = 0; // variable for reading the pin status
int val2 = 0; // variable for reading the pin status
void setup() {
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(inputPin, INPUT); // declare photo interrupter as input
pinMode(ledPin2, OUTPUT); // declare LED as output
pinMode(inputPin2, INPUT); // declare photo interrupter as input
void loop(){
val = digitalRead(inputPin); // read input value
val2 = digitalRead(inputPin2); // read input value
if (val == LOW) { // check if the input is LOW
digitalWrite(ledPin, LOW); // turn LED OFF
} else {
digitalWrite(ledPin, HIGH); // turn LED ON
if (val2 == LOW) { // check if the input is LOW
digitalWrite(ledPin2, LOW); // turn LED OFF
} else {
digitalWrite(ledPin2, HIGH); // turn LED ON
Under normal conditions the petcock should be activated by an engine vacuum. If in fact the petcock is seeping some fuel by then the carb floats should also prevent the fuel overflow into the cylinders. This issue could be a combination of both or it could a couple other things too.
1. How's the plugs look? If you are burning excessively rich then the unburned fuel could be seeping by the piston rings and into the oil.
2. What's your current mileage? Have you always had oil changes done on regularly intervals?
3. Is the petcock in the "On" position or is there a chance it could be in the "Prime" position?
4. Do you ever see or smell fuel leaking out the overflow tube under the bike?
IMO... I'd say it's prolly just time to do a carb rebuild and make sure those float needles are sealing good. :2cents:
Code:int ledPin = 12; // choose the pin for the LED int ledPin2 = 11; // choose the pin for the LED int inputPin = 2; // choose the input pin int inputPin2 = 3; // choose the input pin int val = 0; // variable for reading the pin status int val2 = 0; // variable for reading the pin status void setup() { pinMode(ledPin, OUTPUT); // declare LED as output pinMode(inputPin, INPUT); // declare photo interrupter as input pinMode(ledPin2, OUTPUT); // declare LED as output pinMode(inputPin2, INPUT); // declare photo interrupter as input } void loop(){ val = digitalRead(inputPin); // read input value val2 = digitalRead(inputPin2); // read input value if (val == LOW) { // check if the input is LOW digitalWrite(ledPin, LOW); // turn LED OFF } else { digitalWrite(ledPin, HIGH); // turn LED ON } if (val2 == LOW) { // check if the input is LOW digitalWrite(ledPin2, LOW); // turn LED OFF } else { digitalWrite(ledPin2, HIGH); // turn LED ON
