Not sure what OP is building. When I hear of a gazebo I think of something like this, maybe even 6 or 8 sided.
Those angle braces are what provide all the lateral stability. The structure could just sit there on top of the deck and not be fastened down at all except to stop it from blowing away in the wind.
Another method is to build it like a pole barn.
Unless something like utility poles are used though you are pretty much leaving the longevity up to fate.
Sleeving or cupping the wood in plastic, metal or concrete just retains water that has seeped into the wood from above and traps that moisture inside, assisting the rotting process. It helps to coat the sides of the post that will be underground in a 50-50 mix of diesel and motor oil (or something similar) to minimize water entering the post. DO NOT cap or in any way seal the bottom end of the post....instead, allow water that has entered to post to seep out the bottom into a bed of packed pea gravel below the bottom end of your wood posts. DO seal and/or cap the top of the post to minimize water getting into the wood.I don't know nothin' bout nothin', but I wonder if you could sleeve the posts in plastic for the underground portion. Seems obvious to me, so maybe there's a reason that isn't done.
My professional project creator (wife) keeps moaning about a pergola. If I want something that will last until North Korea does us in, would it be feasible to embed stainless steel threaded rod in concrete footers and then bolt the posts to the rods via some bracket? 5/8" dia rods 1' long are only about $7.50 for 18/8 and $15 for 316 on McMaster, so it really wouldn't be that much cost for something that lasts forever. Why do I never hear of pergolas being attached to threaded rods embedded in concrete?
Eliminate rot? That's funny. YMMV when it comes to treated lumber. Honestly, 4" vs 6"....you go with thicker stuff if you don't want it to rot as quickly. Water typically doesn't go as deep underground as you think. It's more than likely going to rot just above ground than below.
Most of the time, they say to put a few inches of gravel in the bottom of the hole for drainage. The concrete base of 1" won't do anything but crack if it cures before you put the posts in....unless you mean to just put dry concrete in without water....it will harden eventually by soaking up water and when you pour mixed concrete on top, the moisture will help it cure with the green concrete above.
The way most contractors handle posts these days is to pour those tubular forms full of concrete to a particular depth/height above ground...and sink a steel post mount in it. Then you bolt your post to the mount. That keeps the post above ground, making no contact with the masonary (only the steel)...so it lasts longer in theory....but the sun will still cause damage if you don't treat it. Just expect 20-25 years max out of posts. If they last 30+, they'll likely be weathered and have cracks running down them. If they're long 4x4s, expect the to twist....long 6x6s, expect them to bow.
That would work, though most of the hardware you're going to find will galvanized. Simpson makes all sorts of post bases and hold downs.My professional project creator (wife) keeps moaning about a pergola. If I want something that will last until North Korea does us in, would it be feasible to embed stainless steel threaded rod in concrete footers and then bolt the posts to the rods via some bracket? 5/8" dia rods 1' long are only about $7.50 for 18/8 and $15 for 316 on McMaster, so it really wouldn't be that much cost for something that lasts forever. Why do I never hear of pergolas being attached to threaded rods embedded in concrete?
