To begin, i was on my pc and it was working fine. Out of the blue, it locked up, having never done this b4 .
So, i go to reboot and it instantly goes to POST code FF, no beep, nothing. Monitor light flickers and displays the screen that it would when its not connected.
I then go through the basics.
Try a different monitor, no luck.
Try a different video card, no luck.
Remove 1 stick of ram, no luck.
Swap ram, no luck.
Try a brand new power supply, no luck.
Finally, i tore down the computer and ended up with just the mobo, stick of ram, video card, and heat sink on my desk, eliminating all possibilites........but no luck. So, i swap in a new chip, no luck. Having checked and swapping everything out except the mobo i feel that i have a bios issue so i buy a new mobo. Guess what, same thing!
The specs are, AMD 2700, EPOX 8RDA3, Radeon 9600XT, Antec 450w powersupply, 1gb of crucial ram (2 512mb sticks). The new mobo i bought is an ASUS A7N8X-E. The chip i swapped out with my 2700 is an amd 1800. Ive tried both chips in both mobos and both power supplies with both mobos, and have tried 2 different video cards.....even an old pci video card. The only thing that remains the same on my system is the heatsink(alpha). Could this be causing a short or something? I dont see how it could be, especially when this problem happened while running the computer, and with all the times ive taken it off and reinstalled it i cant see the possiblity of it happening everytime.
I did a search and there were some threads relating to this problem, but nothing specific and nothing with a specific answer.
HELP!
Swap ram, no luck.
HELP!
