I'm having a problem with my computer running extremely hot after sometimes 5 to 10 minutes of usage.
Both the case and the fan vent from the power supply warms up. It doesn't happen everytime I turn on the computer, but it happens frequently. The computer will freeze up after booting up and I have to reset - turn the computer off/on about 2 to 3 times before I can use the computer. Before I go out to buy a power supply, I need to know if what I describe is a possible power supply problem. I have opened up the case and removed all dust from the inside recently, but it still runs hot. Its giving off an odor almost like a burning smell when the computer is running. This doesn't happens all the time. I have put my hand on the case and the power supply fan appears to be turning, but I'm not completely sure if it is or not.
