Originally posted by: johnpombrio
If you could, just paint the damn things a different color.
If the robot can just go in, have it carry a spray can and a solinoid to trigger the spray can.
Stick a magic marker or a sponge full of paint on the end of a stick and run it into a pipe to create a dot pattern.
If the pipes are hot, stick a marble with a high temp slow set epoxy onto the end of a stick. Stick it to the pipe. Use different colored marbles or different number of marbles.
Stick a kids sticker of a different flower shape on each of the pipes or on the sphere near the pipe.
Create vertical stripes on the ground with paint in various patterns.
No paint, no stickers, no epoxy - all of those are potential sources of chemical contamination that will promote chloride stress cracking at high temperatures and pressures. These are nuclear reactor parts - cracks are "bad."
degibson, I'll look into a sonar approach. They put those little sensors on so many car bumpers now, they must be cheap and reliable. I don't think the radiation field is strong enough to keep them from working reliably. Even so, they could change out the sensors for next to nothing.
and - this robot has no processors - it is controlled solely by a remote joystick, driven by someone watching video from onboard cameras. The composite video umbilical cables it pulls is one of the biggest drawbacks it has.
