"Portal" game, Flash edition.
jagec
24,442
Originally posted by: Eghck
SPOILER FOR LEVEL 9!!!
you just shoot up above and below and while you're falling shoot the ground so you'll end up shooting up the new portal with the momentum you gained in your freefall.
I quit on 24
Actually, I may have found a cheat for 9. I was able to make a portal on the TOP of the roof, and I would basically bounce up a little through that portal, fall the short distance back into it and through the other portal, then fall back into that one and so on. I wasn't quite able to get my guy far enough over to hit the top of the ledge, but I bet with practice you could.
The problem is that if you bounce too high, your character respawns in the entranceway. Clearly I wasn't supposed to have a portal there.
Jeff7
41,596
20
Originally posted by: AnonymouseUser
Originally posted by: mjuszczak
How do you select another level
It doesn't look like there is any way of skipping levels.
Hopefully they add that in the future. I got past level 9 thanks to the hints here, but darn it, I'm not going to leave a browser window open indefinitely for lack of a save feature.
Now stuck on #15.
novasatori
3,851
I used the direct link to save it to my desktop and whenever I load it I can continue, by just going to select level and then choosing the last one I was on
I'm on 37 for now, whenever I feel like playing again I just load it off the desktop :)
Jeff7
41,596
20
Ah, well then, excellent. :)
On 15, I made it to the ledge right before the blue forcefield thing, but then I can't get past that.
Up to lvl 28.
novasatori
3,851
can't seem to get past 37, i get to the 2nd to last room with the laser and my cubes always drop onto the right side of the button where they can't be moved from as no portals can go there...
argh
Nik
16,101
If this is basically the same gameplay as the official Portal game, I won't bother buying the real thing. This blows. :p
Jeff7
41,596
20
Is there any way of picking up a box when standing on it? If I push it against a wall, is there no way to move it away from said wall?
Now I'm at 31. How do I open the door?
Chaotic42
34,778
1,952
Use "f" to pick the box up.
Jeff7
41,596
20
Thanks.
Made it past 31. Now I'm on 32. I almost got the energy ball to the receiver, but it blew up about 50 pixels shy of it.
Originally posted by: 3cho
any luck on 32?
Get the cube to the bottom switch, then you need to get the energy ball to the receiver. It seems that it'll take a lot of careful timing. And that damn energy ball can kill you if you get even remotely close to it.
Bah, Dammit!!! made it to the end of lvl 32, but then didn't see the turret there until it killed me.
Phew, made it.
33 was easy.
34....I don't even see a strategy, much less executing it. Got to get the cube out, but I see no way to do it. Remove the cube, and the door shuts. I can get the cube out of the room it's in, but then I'm stuck there permanently.
Ugh, damn I'm stupid. Got it. :)
This game's hitboxes are quite a bit larger than the objects themselves. I was standing pretty well behind a turret, and it still killed me. Seems that getting your gun in the way of anything dangerous will be fatal.
Geez, after level 37, #38 and 39 were pathetic.
Even 40 wasn't that bad. Minimal peril. I was expecting something like 200 turrets and 50 energy pulse emitters.
novasatori
3,851
holy shit i didn't know i could pick up boxes I made it to 37 w/only portals etc
now that I know, I'm going to try 37 again :p
37 was so easy knowing that, well I beat all 40 now, it was pretty fun while it lasted...
I want portal really bad, but I gotta wait till I can afford it. :/
E equals MC2
Banned
Apr 16, 2006
2,676
At Level 36. Determined to finish this. Every level has been fun. Not to impossibly frustrating or complex. Good stuff.
bucwylde23
4,180
Thanks.
any luck on 32?
Phew, made it.
33 was easy.
can you give a hint for 34? for some reason I can't figure this one out
Jun 4, 2005
19,723
Stuck on 16 with the forcefields and shit. I got up the first level, but now I'm trapped. o_O
EDIT: Oh, you can stand on the thingies. Nevermind. =D
EDIT: God damn it, I thought you couldn't walk through the blue ones or you'd be vaporized, I didn't know they were solid. That woulda helped.
yllus
Elite Member & Lifer
Aug 20, 2000
20,577
432
I'm on 36 myself, but took a break because 32 took me a dozen tries and kind of tired me of the entire game.
Dec 27, 2001
11,272
For 15, get to portals open infront of that glass wall and jump down into them so you have momentum.......while you're in the air you can aim over the glass and hit the white landing area infront of the zapper. Make sure when you open the first pair of portals that you do the near one first because the momentum you get from falling back through it is what will lift you onto the zapper platform. From there just jump.
