EliteRetard
Reviews are quite positive for the 4900HS and it's IGP, I think it would be great if they offered lower cost H CPUs with that full IGP as well.
Reviews of the full 8 CU IGP show it's just as fast as (often much more than) a Nvidia MX150 / MX250 / MX330 / GT1030 (all rebadged same GPU)
Why force people to pay for all the compromises of a dGPU if they really don't need it? Higher price, weight, size, lower battery life etc.
Forcing people to the low performance U series is not the right attitude or answer either. "Only hardcore gam3rZ need high performance CPUS!"
A theoretical 4600HG (G for graphics, meaning FULL IGP) vs a U series + dGPU would be less complex and much cheaper to produce.
It should offer the same or better GPU and CPU performance in a similar total power envelope (15w CPU + 25w dGPU vs 35w to 45w APU).
Because of the dynamic nature of these new AMD APUs, they have the potential to entirely upset and change the current market.
I guess I'm just really enthusiastic about these new chips, and the large efficiency and performance gains they've brought.
I want to see designs using these powerful Ryzen H chips without a dGPU, the full IGP is good at no extra cost and fast enough for many.
Cutting down the IGP for no reason and trying to force it to also be a product differentiator is just a bad thing, the CPUs already do that.
Nobody is going to spend a lot more for a higher tier CPU they don't need just to get a better IGP, and it's disappointing to "settle for less".
Offering a full power IGP on cheaper tier CPUs however can pull people over from competitors that don't offer such performance for the price.
It literally costs nothing to keep the full IGP enabled on the lower tier chips, all the R&D manufacturing and hardware is physically there.
This is how I see things:
U series for the tech illiterate, for super light office work or web browsing only. Niche 90+ Wh units for maximum battery life.
HG series IGP ONLY for those who need a high performance CPU and sick of paying (cash, battery life, size, weight) for a dGPU they'll never use.
. . . 4600HG could be a great mid-range option, just the right mix of performance and efficiency, perfect for enthusiasts and light gaming normies.
H plus dGPU for the hardcore gamers or anybody who needs GPU power for specific workstation tasks.
What say the rest of you?
Edit: Slightly modified to suggest a full lineup of HG parts that would offer the full IGP. I think there could/should be full IGP only options from R3 all the way to R9. I focused on the R5 since it would be a great mainstream option, and the R9 is already a full IGP (and they need to offer laptops using them without dGPU). The current units with cut down IGP can be used in laptops with a dGPU for those who want that.
Random example: All else being equal (performance, chassis, screen, keyboard, wifi etc) what would you choose?
Intel U series + MX330 for $750 w/ 6hr battery and 4.5lb weight (higher cost due to added dGPU)
AMD HG (full IGP only) for $675 w/ 8hr battery and 4lb weight (higher battery life, lower weight due to lack of dGPU)
In actuality it's likely the AMD system would have a higher performing CPU since it can use the full 35-45w vs the 15w of a U series.
Unfortunately AMD isn't offering such a CPU/configuration because they are trying to conform to the standards Intel has set up to now.
Maybe, hopefully, by voicing my opinions and getting others to share we can catch the attention of somebody who can make it happen.
