Poll: System Builders do you put in all 8 screws for Optical Drives?
Originally posted by: goku
How the FSCK would you put more than 4? Is that even possible?
Op[tical drives have 4 holes on each side, while HDD's only have two.
Just checked, I use 4, not 2..
Originally posted by: PlatinumGold
be honest now.
how many of you honestly put in every screw when building a system?
No, you are not supposed to use all 8, you use 4 the other 4 are in case your rails require different mount points.
Originally posted by: yllus
At Best Buy, I usually lived on the edge and put in just one.
Kidding, kidding. 😛
LOL you may be kidding, but I'm sure many BB builders might not find the joke ha.
If there's space for 8 I put in 8, why you ask? Workmanship, I have a good reputation for building clean PCs over the years, & an extra 30 seconds of your time to screw in a few more screws why not? Worst it can do is keep the drive & case stable if it's spinning a CD at 52x.
Originally posted by: Pepsi90919
with rails, 0. without, 4. how the hell do you fit in 8?
there are 4 holes on each side and most optical drives i've worked with have 2 sides. 😉
WTF kind of Optical drives have only 1 side?
Originally posted by: Trygve
Never. What's the advantage of using more than four? I would assume the reason for the eight holes is to accommodate different mounting rails and cases.
Yep, that's what I always figured too.
4 screws - top right & bottom left on both sides.
A two-dimensional one?
you guys haven't seen 1 sided Optical Drives?
it's an OPTICAL ILLUSION. 😉
8 is nowhere near enough. I need waaay more than that. I drill extra holes in my drives so I can put in 64 screws! 😛
Anyways, 4 is more than enough...
64 screws to go with you 64 bit processor huh?
