Poll: Recommendation on a GeForce3 TI200
AGodspeed
3,353
Arg, hard decision, i'm leaning toward the eVga and the Leadtek tho.
Go with the Leadtek if you care about 2D image quality at all. If you don't care about 2D, get the eVGA.
Good luck!
pookguy88
1,426
My Visiontek Ti200 is at 220/500 quite stable, how do i look for artifacts in 3dMark?? is it only in some tests?
or will all tests have artifacts?
what exaclty am i looking for?
Demonicon
570
For artifacts you have to look very closely, I notice them right away on the low detail truck demo looking straight ahead on my monitor, somethimes the are streaks of darker shades, specks of white. Look closely and you will notice them if they are there.
NOTE:If you see something abnormal in 3DMarks, hit escape to exit the test.
bjc112
11,460
no go gainward.. overclocks just as high as leadtek, prolly higher... plus Gainwards 2d will be just as good... the 2d on the leadteks is top notch for the TI 500 though... :p
ShadowFox
304
I went to Leadtek's Website and saw that the have released the "winfast Ti200TDH" the tdh apparently means that it has temp, voltage and other hardware monitors,
so i'm sticking with the Leadtek. :)
BFG10K
22,709
3,002
Definitely get the Leadtek. I have the Ti500 and it's absolutely superb.
ShadowFox
304
Yep, Leadtek Ti200TDH, i'm going to order it from Googlegear (Newegg doesnt have the TDH version), should get it in about 10 days, i'll let you guys know how it worked out;)
Rickten
1,607
I too am going for the leadtek ti200 tdh. I need a dvi connector and those hardware monitors look sweet. Also its cheap.
