POLL: manual drivers, do you wiggle the stick to make sure your in neutral?
paulney
6,909
Originally posted by: Aharami
i do it all the time, cuz if im goin on a downward slope, i just put the car in neutral and let go of the gas (that is, if the angle of the slope is enough to sustain my current speed) --> save as much gas as possible
Prepare to be flamed off the Earth. Oh, and just in case - for a nice ticket, too. In case you don't crash earlier.
dpm
1,513
Before I start the car I do. My mom always used to leave the car in gear, which drove me mad, but instilled the habit of checking to make sure.
Demon-Xanth
20,551
Sometimes, but rarely. I need to clutch it to start the car, and I leave it in gear when parked. When I take it out of gear, I already know it's out. No wiggling required.
paulney
6,909
Service guys always do that, and I always forget to check if they did or not. Drives me nuts.
jjones
15,424
Not very often at all. Sometimes when I start the car and get interrupted in the process (family distractions), I'll have the clutch in but forget if I took it out of gear or not. I'll wiggle it to see if it's in neutral so I can let out the clutch and finish whatever needs attention before I drive off. Once I'm driving around I probably never do that.
Jzero
18,834
Well you "should" always park it in gear. It's just another thing you can do to keep it from rolling away. I hate it when people don't....I get in the car, start, pull back to put it in neutral and wonder why it didn't feel right :)
paulney
6,909
Maybe you shouldn't be so cheap and maintain your parking brake tight? :)
Don't want to start another holy war or anything - this has been discussed way too many times. I don't like leaving car in gear when it's not warranted. My parking brake has plenty of gripping power to keep the car from rolling. Of course, if I'm on a hill or smth - I do put it in gear in addition to a brake.
Doggiedog
12,780
Yes, but I don't wiggle it too hard because I don't want to accidentally put the car in reverse. :)
Aharami
21,205
165
prepare to bend over and kiss your own @$$. ticket? crash? wtf are u talking about?!!
Jzero
18,834
It's just an extra layer of protection, it's free, and it requires no extra effort. Why not, then?
That's they way I've always looked at it.
LAUST
8,957
I'll trust a tranny gear long before I trust a wire thing brake cable
brxndxn
8,475
Originally posted by: Sid59
it's more habit and something that's instinctive .. passes the time.
if you don't know that you shifted into neutral and do it to check .. you shouldn't be driving.
FU bish.. I always forget what gear I'm in cause' there's always a million things going on in my head. Also, I have a Hurst short shifter so sometimes it hangs between gears if I just tap it.. Wiggling makes sure I don't get the nasty grind and "OMG, I hurt my car!" feeling.
Vic
50,422
14,337
Yep. Just a habit that I don't even think about. Anyway, better to check and be sure than to screw up just once in your life and let the clutch out while in gear and cause an accident. At least that's my reasoning.
Chiropteran
9,811
110
Check to make sure of what? Doesn't the clutch have to be in to start your car?
I always park in 1st and start the car in 1st and never even shift into neutral, what is the point?
Vic
50,422
14,337
Hanging out at stoplights with the clutch in and the tranny in gear is a good way to wear out your clutch prematurely (especially the throw-out bearing). Plus my leg gets tired at the really long lights.
Chiropteran
9,811
110
Apparently I read what you said wrong. You said your mom left the car in gear and I thought you ment you had to shift to neutral before you started the car after your mom used it. I think what you were really saying was that your mom just used the clutch and rarely shifted into neutral while waiting at stop lights, now I get it :)
