Originally posted by: whaleskinrug
I think maybe I will finally adopt the metric system after years of resistance -- it is far more descriptive![]()
174.00 cm = 68.50 inches
Why does your metric answer have more sig digits than your original measurement?
I yanked it off the web conversion page, rather than type 174 cm = 5'8.5"00's are not significant
if you are measuring height to many thousands of an inch then there is something wrong-- even if it's 174.00005 it's really no different. so these 00s are not significant.
When you state 5.0000" in place of 5", you imply that you're precise to four decimal places, therefore they're significant. If you add zeroes, you're making up the precision.
