Poll:Gas Station question?
dragonballgtz
Banned
Mar 9, 2001
2,334
Originally posted by: ggavinmoss
Even if car explosion is unlikely, why give crooks an easy target by leaving the car running?
-geoff
:thumbsup: Well said. I know people that left thier car running and the next thing they know thier car is gone.
His Lord Uberdude
532
Once while filling up, I noticed the guy next us was running while filling. It was like -15 with a wind chill that day, so passengers inside had demanded it be left on, I guess. Then we sat there for a REALLY long time while the tank filled up, when we noticed it wasn't filling because the pump was leaking. :shocked: So, we reported it, went to another pump, and ANOTHER guy pulls in and starts pumping and filling!!!!! :shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked: AND THE PUMPS LEAKING!!!!!!!! :shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked::shocked:
THEN as we were leaving (lucky to be alive) someone ELSE started filling while running the engine!!!!!!!!!
Indolent
2,128
Originally posted by: torpid
Originally posted by: Amused
Originally posted by: rh71
The one thing I know for sure not to do is to get back into my car while it's filling... with all the static electricity...
You can get back in your car. Just be sure to ground yourself before touching the pump handle again.
Here in IL when it's below 0 and windy, I ALWAYS get back in the car. I just ground myself after I get out again.
Erm... wouldn't it be a problem if you touched any metal part of the car while you were getting out?
Not if you do it away from the nozzle where there are no gas fumes.
Amused
57,355
19,536
When I get out I touch the car, then walk around the car to the pump island on my way back to where I'm filling up and I touch the side of the pump. Then I feel safe touching the pump handle again.
The danger lies in having a static charge in your body and touching the pump handle. Touching another part of the car or pump far from the fumes shooting out of the filler hole is not a problem. The spark HAS to be right near the area the fumes are in a high enough concentration to ignite. That is only right next to the filler hole/pump handle area.
moshquerade
61,504
12
56
ok, then answer me this: there is actually a full service gas station near me where they pump the gas for you. of course the gas is a little more expensive, but i go there when it is freakin cold out or raining cause it's worth it to me. so anyways, when it's cold they have told me i can leave the car and running and "stay warm" while they pump the gas. wouldn't you think they know what the fvck they are talking about? why would they do this if it's so dangerous?
Mayfriday0529
7,187
My friend does that at a full service station, he leaves the car on all the time and the attendants don't care.
moshquerade
61,504
12
56
i really think it's an old wive's tale that your car will "blow up" if you leave it running.
Kelemvor
16,928
8
You can fill gas without shutting off the engine with usually no problems, but why waste the same gas you are adding to the car?
torpid
11,631
11
The problem is only if your car backfires which may or may not result in bad things.
My car at least will freak out if the gas cap is not on while the car is on.
jagec
24,442
It is. Why WOULD it blow up if you leave it running? The exhaust pipe will be just as hot if you leave it running as if you JUST shut it off. That said, I shut it off, and I never get back in the car while pumping.
Nitemare
35,461
4
I heard they were going to let the drivers in Nascar leave their cars running when they get fuel this year as well....
Urban legends, peeps
Juno
12,574
Originally posted by: flamingelephant
in canada its illegal, and if I see you doing it I'll write you a nice ticket (environment officer here)
Hey, I'm going to Toronto in few weeks~! Be prepared! :p
Ime
3,661
I always turn my car off and pocket the key. I could just see someone jumping into my truck and driving away if I left it running!
TravisT
1,427
If it is really cold I sometimes leave it on and get back in the vehicle. But probably 95% of the time I turn the vehicle off. About 50% of the time i get back in waiting for it to fill up.
Pantoot
1,764
30
I actually failed emissions cause the check engine light was on because the gas cap was not tight enough.
Mayfriday0529
7,187
You put the gas tank lid to let it pump on its own?
don't they have signs that say don't do that?
