POLL: does your 2500+ hit 3200+ speed on default voltage ?
Soulkeeper
6,735
155
Only select yes if the system is "fully stable" 24/7 (games, seti, prime95, or whatever you use)
btw mine needed a small boost if i remember correctly
Megatomic
20,127
Yes, my chip does run at 3200+ at stock voltage. It has done so since the first day I got my chip (last summer). It is Prime95/3DMark2K1/Winamp stable for over 48 hours (all looping at the same time). I love my chip. :heart:
Shimmishim
7,504
you still using that nf7-s v 2.0 that got banged up? :)
DAPUNISHER
31,920
32,164
My week 13 2500+ did 2.3ghz on less than default voltage *actual 1.632-1.645v* under heavy load.
SKORPI0
18,471
2,412
Yes.
2500+ AQYFA 0343XPMW @ 3200+ w/ 1.65 Vcore
Gigabyte GA-7N400 Pro F12 Bios
768 mB (3x256) Geil Ultra Platinum DDR433 (PC3500)
PNY GF4 Ti4200 8X 64 mB
Chieftec BX-02B-SL-SL
BlueWeasel
15,944
475
well, at least I was the first to pick "Other hardware won't let you OC that far" :)
My Epox 8RDA doesn't like anything over 183 FSB without modding the voltage to the Northbridge, but it's running fine at 11x183 = 2.0ghz at stock voltage. I figure I'll be able to hit 200 FSB just fine once I get a new board.
WobbleWobble
4,867
I see you created the poll :)
There is still a difference between being Prime95 stable being able to run your games without errors. Like I said before, not everyone believes in running stability testers and if the overclock is stable enough to handle what they do it's a good overclock.
I think that may skew the results quite a bit. I hate to sound like a whiny little punk, but that's my 2 cents ;)
Megatomic
20,127
Darn right. The thing is a tank. I'm still a very satisfied customer Shimm.
Dustswirl
282
week 19, works gr8 at 3200's speeds, default Vc (1.650V) but i got bored so i oced it a lil more...with a lil voltage increase:D
Shimmishim
7,504
BlueWeasel
15,944
475
Originally posted by: nippyjun
Do all Barton chips (2500+ through 3200+) have the same 1.65 default voltage?
Just checked Newegg, and the default voltage for a 3200+ is listed as 1.65v
t4t3r
277
mine did until i threw the ut2k4 demo at it. up until then it ran at 3200 at 1.65. gonna try 1.7v tonight on 3200 and see if it is stable again.
JimRaynor
1,593
maybe it wasn't actually "stable" at all, you have to try and get it truely "stable" for the first time
WobbleWobble
4,867
That's the problem with polls like this. People have different definitions of stable. To some, if it boots Windows, it's a good overclock. To others, if it runs regular stuff, it's stable. Others run tests, then it's stable.
Also things like how intense a program is, sure I can run Starcraft no problem. But since i don't play UT2004, it doesn't matter if it crashes when I play UT2004.
Soulkeeper
6,735
155
yeah i agree maybe i should start another poll on what people consider to be stable j/k
haha
