the vapor is what you should worry aboutOriginally posted by: Beattie
Originally posted by: LAUST
No, it not only makes your fuel pump work harder but having it submerged in fuel helps cool it.
Do you run your CPU without a heatsync?
There's just something about the idea of using a flammable liquid to cool a hot component that seems wrong...
Originally posted by: Chiropteran
Unless I'm visiting my mom in Woodbridge where the gas is cheap, I don't fill up until the little red light comes on.
but have had hesitation issues with our '90 Accord where it sometimes wouldn't accelerate at all. Cleaning the fuel injectors did nothing to resolve it. Full tune-up either. After spending hundreds in diagnostics/fixes, all it took was a new O2 sensor (noticed fuel efficiency was sucking).
Originally posted by: rudder
I can drive about 80 miles once the fuel light comes on so I don't worry about it too much.
That's my paranoia. More gas and gas vapors in tank --> less space for water vapor.Originally posted by: bmwgolfer
I don't let the tank run on empty. Especially in the winter...I hear condensation can build up in the tank and that'll cause problems.
