Originally posted by: TheLonelyPhoenix
You shouldn't be backing your thermostat off to 45 anyway, as a pipe can freeze and burst. I believe 60 is a minimum
When your thermostat is up around normal, you only have to generate the heat to replace what you're losing through the windows etc... which is negligible compared to the space in the rest of your apartment. When moving up a degree, though, you have to heat ALL the air in your apartment up a degree, a much greater expenditure of energy.
I usually kick it down to 65 while I'm out for the day, back to 72-75 when I'm in.
Originally posted by: Slvrtg277
There are a lot of variables in a topic like this one.
Originally posted by: KarenMarie
I thought that it saved money and energy to leave the thermostat at one temp... like 68 degrees... all the time as opposed to turning it up or down.
water doesnt freeze at 45.
This tip was actually on my utility bill a few months back, albeit for summer use of the air conditioner but the general principal is the same, but I still don't understand why it would work, intuitivelyOriginally posted by: KB
Did this expert work at best buy? Sure it takes longer to heat up later in the day, but you won't be paying to keep it higher while you are away.
Yea, but your pipes aren't all located at the thermostat.
If you set it to maintain 45 degrees at the thermostat, you could easily be at risk to freeze a pipe in a crawlspace or such.
Originally posted by: flot
I'm no expert, but I've put some thought into it, and I'm pretty sure you would *have* to determine this on a case by case basis.
The blanket statements don't take all the variables into account - especially things like how well insulated your house is to begin with, etc.
If you have a gas furnace, it's actually probably pretty easy - you have a gas meter you can read, right?
Pick two days where the conditions are approximately the same. Use a 24 hour period - record your gas usage for the first 24 hours doing it one way, then for the 2nd 24 hours immediately switch to the other technique. See what your actual energy consumption was. (And don't use any other appliances that use gas)
I wish I could do something similar, but there's no way for me to get much of an equivalent here in south florida - I could watch the electric meter but there are way too many other variables over the course of 2 days... with gas you could probably pretty easily live without the other gas appliances in the name of science. 🙂
the variables basically adjust the time you have to leave it lower before the numbers start to work in your favor...for most homes that don't have a heat pump, it's roughly four hours.
If you have a heat pump, setting it back is almost never a good idea.
Originally posted by: timswim78
My experience has been that it is definitely less expensive to maintain the temperature rather than let it fluctuate. This is especially true when it is very cold or very hot outside,.
Originally posted by: nwfsnake
Not sure you guys are correct. You are not only heating the air, but the furniture, walls, cabinets, etc...
When you turn it down, assuming everything has achieved a steady state temp previously, everything in the house gets cooler. To heat it back up again, you have to heat everything. There is probably some temp delta, say 10 degrees or so, that is the most efficient. I think I will google and look for some more input.
Originally posted by: aircooled
Don't forget about the fluorescent lights. The ballast/starter uses more energy to turn them on than it does to keep them running for an 8 hour day. Turn them on and leave them on until closing time.
That seems to be another misconception. From here
"Many people continue to believe that it takes significantly more electricity to turn on a fluorescent lamp than to operate the lamp for long periods. Modern fluorescent lamps, however, use little starting energy. Turning them off actually helps them last longer and lowers lighting energy costs. Researchers at the U.S. Naval Civil Engineering Laboratory have found that a fluorescent lamp?s initial "start surge" lasts only 1/120 of a second. The entire starting current for two-tube rapid-start luminaries lasts less than one second before it stabilizes. Consequently, Navy engineers assert that turning the lamps off for only one second saves the energy required to turn them back on.
Not only does turning off fluorescent lights reduce lamp replacement costs, it also reduces electric bills. For example turning off a single one-tube light for only one-half hour a day can save about $3 in energy over the life of the lamp. In fact, the money saved by this routine is typically more than the price of a new lamp.
In short, you should turn off lights in your office or a room in your home when you leave, even if you leave for only a few minutes."
