Hi guys!
A couple months ago my 9600gt fan has begun making an insane amount of noise...
I have a couple of things that I'm going to try to get it to try to make it a bit quieter, but so far I'm not having much luck.
My friend gave me the idea that I should put on an aftermarket cooler instead of buying another card -- I thought it was a great idea. Now, I need help knowing what fans will fit the 9600gt.
If anybody has suggestions for a cheap fan, that would be great -- I'm not looking to spend a fortune because this card is only worth ~$80 right now..
Thanks!
JFT
Thanks!
JFT
