I'm starting from a fresh clean reformat using XP SP2, RivaTuner 2.0 RC15.2, ForceWare 66.93
Whenever I enable to extra piplines, I am prompted to reboot, I reboot, it never makes it back to windows. The only way to fix it is to go to safemode and uninstall rivatuner. I believe that something is wrong because everyone else is talking about getting artifacts when the pipelines do not work
Here is my procedure:
1) Low Level Settings > NVStrap driver tab > Install
2) Set to custom > place checkmark for bit 00 > confirm
3) hit checkbox "Allow enabling hardware masked units"
4) Asked to reboot > never makes it back to windows! It gets to where the mouse cursor loads with black background then it reboots itself in a loop.
What am I doing wrong?
Comp Specs
Athlon XP 1800+
Epox 8K5A2+
768mb PC2700 DDR
PNY Geforce 6800 Regular
Comp Specs
Athlon XP 1800+
Epox 8K5A2+
768mb PC2700 DDR
