Extelleron
- Dec 26, 2005
- 3,127
- 0
- 71
The short answer to this is that every Intel quad-core CPU is better than any AMD Phenom in every scenario imaginable (other than synthetic memory benchmarks). The X4 9950 BE is pretty much equal to the Q6600 in stock performance, but overclock the two and there is no comparison. And the Q6600 is significantly cheaper.
As for Intel's dual-cores.... in multi-threaded benches the Phenom 9500 will be (slightly) faster than a fast dual like the E8xxx series, but not by as much as you might think. I suspect the E8600 will come awful close to the 9500's performance even in apps that make use of 4 cores. In apps that don't make use of 4 cores... there will be no comparison.
I've been a big AMD fan and I still prefer their processors, but I'm not going to constantly settle for less supporting a company. I bought an AMD Phenom and it was alright, but not good for my purpose (gaming). And trying to overclock it is simply a PITA, especially since the motherboards are not mature and the low-end boards have trouble running some of the CPUs because of crappy PWM's / the high power consumption of Phenom CPUs. If my motherboard had been solid and the prices of Phenoms lower, I might have upgraded to a 9850 / 9950, but that's just not the case. With Phenom, you can't just go out and buy an $80 board and be fine like you can with Intel. You need a $150-200 790FX board to run a Phenom CPU well, and that would kill any price advantage even if AMD had one. But they don't, because Phenom 9850 / 9950 cost more than the Q6600 yet they are slower.
My overclocked E8400 outperforms my Phenom 9500 oc'd across the board, even in Cinebench which makes use of 4 threads. And now I can use 64-bit Vista, which just makes the margin even larger. B2 Phenoms will not overclock well in 64-bit Vista for some reason. Plus you have to constantly worry about disabling the TLB patch before you do anything.
