plz help w/TV recommendation - LCD ~32" must have ability to stream from media server
robphelan
4,084
17
I'd like to buy a new TV for the bedroom but it must have an intuitive interface to access the shared network drive that has all our movies/TV.
Also, access to Netflix etc... I do have an ethernet port close, so wifi isn't a requirement.
I'd prefer LCD over plasma since I can't put up with all the glare. Price isn't a huge factor, I just need it to be relatively simple for my wife to operate.
What would you guys recommend?
thanks a ton.
EDIT: I should also say that we probably won't have a cable box connected to this TV - so it won't have HD access other than what's streamed from my media server.
Those files will be a mix of .avi, .mkv and 264.. so, it would be great if the TV supported all those formats.
robphelan
4,084
17
I think it might be better if I went the HTPC route. I'm doing this already in the living room - using XBMC as the frontend - and it's working great.
I do have a spare PC with XP just sitting around I can use.
poofyhairguy
14,612
318
That is what I was going to suggest. That way it can play any file and you can get a TV based on value.
