Plumbing couplings help
NetWareHead
THAT guy
Aug 10, 2002
5,847
154
I need to join 2 pipes together and understand I need to use some sort of banded coupling to do so, but not sure which one. I've heard of various ones: mission, fernco etc... Some have 2 bands, others have 4. Some clamps are just a rubber sleeve and others have a metal shield.
I need to join a 3 inch schedule 40 PVC pipe to a 3" cast iron pipe (not sure yet if SV or XH). This is for an above ground DWV application (not buried) and will be in an interior wall. Amy suggestions?
jmagg
2,238
470
I went from vertical 3" sch 40 to 4" inch cast with an "Americanvalve" rubber coupling 2 clamps total. Not a problem nary a drop. I think the metal sleeved couplers are for horizontal applications for added rigidity.
Greenman
22,352
6,494
They sell what you need at the homie. Just a basic band for nohub cast iron will work.
