Please review HTPC build
RevoHos
I'm looking to build a new HTPC. For now, I will be looking at just streaming. I think I have everything except OS and Power Supply. I plan on running XBMC with it. I'm looking for recommendations on the Power Supply and if I need a CPU cooler other than the stock.
In the future, I am thinking of adding a Ceton and possibly a video card to do some light gaming.
http://pcpartpicker.com/p/zl0d
I'm open to any other suggestions or add-ons that you may think suitable. I do not have a budget other than trying to keep it under $1000.
In case you guys don't like my pcpartpicker link:
AMD A10 5800K
ASRock FM2A75 Pro4-M
Corsair Vengeance 16GB DDR3-1600 Memory
Corsair Force Series GT 90GB 2.5" SSD
Silverstone SST-GD05B HTPC Case
LG UH12NS29 Blu-Ray Reader, DVD/CD Writerhttp://pcpartpicker.com/part/lg-optical-drive-uh12ns29
http://pcpartpicker.com/part/silverstone-case-sstgd05busb30
Upgrade that ram to 1866mhz and you should be good to go with light gaming. I have a very similar HTPC build except I went with the Asrock A85X motherboard. I would recommend a decent CPU cooler as the stock one is horriblePosted from Anandtech.com App for Android
To me the A10 processor and 16gb RAM seem like overkill unless you're certain you're going to be gaming. <$500 is adequate for a HTPC budget, if you're going to build a gaming rig build it for that purpose, it will be more than capable at HTPC duties, a HTPC typically makes compromises for cost, energy efficiency and noise reasons and won't be the best machine for gaming.
Cut the ram to 8 gigs and get the fastest ram you can with the original budget. Trinity needs fast memory not tons of it. Plus you should have a nice quick upgrade path as the next generation APU is gonna use the same socket.
This. Hell, as Raspberry Pi can accomplish the streaming (albeit with a sluggish interface), if that's really all you want. It's not worth $400 to have the possibility of gaming, unless you know you want it for that.
@Shaydza Do you have a recommendation for the RAM? Or did you just mean like jr26 stated and go with the 1866?
That's why I decided with the FM2.
@crashtestdummy I'm leaning towards XBMC on top of Win7. I'm slightly afraid of the XBMCbuntu.
Ok, below is a link to an updated build with 1866 RAM and an A8-5500 APU. This keeps with the FM2 so upgrading when the next gen comes out will be possible. I changed the case and added a modular PS as well.
Any thoughts or things you might change are welcome!
http://pcpartpicker.com/p/At9Q
CPU AMD A8-5500 3.2GHz Quad-Core $104.99
Motherboard ASRock FM2A75 Pro4-M Micro ATX FM2 Combo or $71.97
Memory G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Combo or $54.99
Storage Mushkin Chronos 120GB 2.5" SSD $104.99
Case nMEDIAPC HTPC 7000B (Black) HTPC $94.98
Power Supply SeaSonic 450W ATX12V / EPS12V $79.64
Optical Drive LG UH12NS29 Blu-Ray Reader, DVD/CD Writer $49.98
AMD A10, A8 is good enough. You can get Corsair CX430 for ~$17 (promo price at NewEgg). You can opt for RAM @1600 so that will save you few more $$.
