ultimatebob
An Intel 12900KS... 😵
It seems that GeForce 3080's are back in stock. Get a couple of those and mine crypto with them... you'll have the most overpriced space heater of all time 🙂
It's warming up in fits and starts. 59F here in my bedroom right now and I'm wearing a hoody and down vest & a bucket hat. 57F outside ATM at 10:10AM.
That little toylike ~500w (optimistic, it's really a bit less) space heater was, as I anticipated, a good idea in my 10'x10' bedroom. Given the temperate climate it mostly satisfies when coupled with the 250w heat lamp, which I turn on occasionally.
I figure I'll look into the heat pump ideas in this thread. There's a lot more to this 1900 square foot house than this 100 square foot bedroom!
PS Only a seldom occasion that I light a fire in my fireplace, and it's not to heat the house, doesn't seem to do that. But it does warm me physically quick, so my hands don't feel frigid. Maybe 1/2 dozen times/year on average. It also gives me ashes that I use in the garden for fertilizer. I have a LOT of dry firewood from trimming my two plum trees.
It gets down into the upper 30's (F) at times every winter, and occasionally the lower 30's most winters for a few days. There was one winter (about 1992?) when minimum night temperature stayed around 26F for several days running. I left the butter out because it stayed around 40F in the kitchen!It also gets to a minimum of about 40 Freedom degrees, no more than 2 weeks per year over the last 30 of our years, where the OP lives. 😀
Heating is definitely useful, because it does get cool at night, but it's comfy indoor temperature most of the year because it just never gets cool enough to diffuse the day's accumulated heat trapped within the typically stone and concrete and stick living units (probably about 55-65 Freedom degrees through most of winter days, and nights are typically 45-50).
I have a number of space heaters but have never bought one. Found, left here, one given me, and at least 2 are parabolic projection coil heaters. I used to use those parabolics. They are OK sometimes, but when I used one I found myself turning it off after a bit. It's better if you are situated in the throw, of course. Can be efficient. I no longer use them. My favorites now are a rotating (~60 degrees) fanned coil heater in the kitchen, a 250 watt heat lamp facing down from the ceiling in the bedroom and a tiny 500 watt (489 watt, actually) thing that's fanned I bought off Amazon. Yeah, forgot, I did buy that one!I have discovered parabolic heaters are quite an effective twist on radiant heating. Failure mode was the overheat buzzer triggering because the metal dish was covered in dust.
I didn't buy. Someone died; made it to almost 100. Their senior children decided to sell the house...probably after noticing a rodent infestation. This heater wasn't given to anyone, it was actually put curbside as trash.
I haven't done my homework yet. Once I get past this winter (this one's been more challenging than most) I can hopefully think about getting into determining what would work for me and how to proceed. Woke up early this morning and it was 48F in my bedroom, 50F in the kitchen. Turned on my dinky heat-em-up systems and gained ~5F in both rooms. I'm pretty used to this stuff.Did you ever look into heat pumps? They're perfect for your climate, and there are now potential federal tax incentives.
You are probably in a well insulated shelter / cottage / cabin etc.Whatever you're doing, or trying to do is obviously not working as well as you've convinced yourself it might be.
That doesn't explain the 30F differential between the inside and outside. You have a potent heat source or YOU are the monster heat source. Must be drinking a lot of coffee or eating lots of protein.Yeah, that's why the wind blows candle flames and draws curtains. This place leaks like a sieve.
There might be difficulty finding this wood thing to burn in San Fran. 😉At this point with price of utilities continuously going up across the board the best bet is heat pump + big solar install, or wood stove. I ended up getting a wood stove myself. I really need to boot it and start actually installing it. I was waiting on someone to help with the chimney but think I need to just do it myself at this point.
