Please recommend me a space heater
BUTCH1
20,433
1,769
A few notes regarding the propane, I use a carbon monoxide detector as a safeguard and the model I linked to has a built in detector, if it's gets too high the flame is extinguished automatically. Since you mentioned your house is old and drafty it won't be a problem. If you run it at say 8,000 BTU setting a tank lasts 3 days, you can keep the tank outside and just run a line into the heater but I didn't bother, propane tanks are fairly robust, just make sure your connection is tight.
Torn Mind
12,078
2,772
I used a Mr. Heater propane heater (with a catalyst) in a room for a month or two. I'm still standing.
Reactions: BUTCH1
BUTCH1
20,433
1,769
"Catalyst"?, I don't need no stinking catalyst!, I just strap one of these to a full tank and let her roar to life, 18,000 BTU at max output, not a great idea if kids or curious pets are around.
Captante
30,353
10,876
In case it isn't already obvious to anyone reading along here.... :oops:
DOING THIS INSIDE IS NOT A GOOD IDEA !!!
Those tanks are intended for OUTDOOR use for a good reason!
images
Sukhoi
15,348
Given the Berkeley climate and your environmental focus I'd highly recommend installing one or two mini split heat pumps. One for the main living space and one in your bedroom. They are vastly more efficient to run than standard electric resistance heaters.
Nov 17, 2019
13,298
7,878
Given the OPs location, climate and proclivities, I'd suggest looking into heating the immediate personal space rather than the entire room. Heated blankets or throws that can be held close. Maybe even things like battery powered heated socks. Perhaps a heated vest?
iu
Battery powered, USB charging. Inexpensive enough to get two or three to keep one fully charged at most times.
There are also ways to heat passively using the Sun if you have the right window exposures.
Nov 17, 2019
13,298
7,878
The wiring here is old knob and tube.
That needs to be replaced, regardless of anything else. I'm surprised you can get any kind of insurance with it.
QUOTE="Muse, post: 40669175, member: 61170"]
My range is gas and I prefer that to electric.
[/QUOTE]
Use it as much as practicable. You're not supposed to use them as a heat source but ..... Consider a large stock pot (10-12 quarts) of water on a low flame. The hot water will act as a heat ballast to help heat the small kitchen and you'll have hot water for coffee, tea, bullion, etc.
Muse
40,866
10,221
iu
I manage in sleep time with my blankets, also wear a hoody during colder weather, a down vest too. It's wake time in cold weather that is the bigger problem. The chill can be daunting. I am set to receive my 500w "toy" heater today. The weather's turned rather spring-like all of a sudden (last 2 days now), will dip a little but come back up next week. Not unlike the last few years here, where global warming seems evident (at least locally). No telling what will happen beyond next week, though. But this weather will make even the 500w heater unnecessary!
Muse
40,866
10,221
I'm wondering... since the multiple setting heaters they're selling now seem to all have minimum 750w draw, is it conceivable to modify them to draw less, say 500w?
Muse
40,866
10,221
Can you link me to some stuff to give me an idea how I'd implement this? Is it a unit I simply install?
13,790
I can't vouch for them but I found these a while back: https://senville.ca/mini-split/energy-star/
I'm kind of thinking of getting one for the garage, if I get one that has 2 indoor units I could put one in my living room too, it gets very cold in that part of the house so having an extra heat source that's also green would be nice.
The nice thing is that it's DIYable so no need to hire someone.
Reactions: Muse
Nov 17, 2019
13,298
7,878
A minisplit can be self install, IF you're handy enough and have the tools. They generally require a dedicated 20A circuit though. The smaller ones may not. Advantage is they're primarily for A/C with some auxiliary heating capabilities. Problem is they're generally in the $1000 to $1500 range.
Reactions: Ken g6
echo4747
1,979
156
this is exactly what I would do. these units are quite efficient. As Red Squirrel mentioned they can be a DIY project. ( plenty of good installation videos are available on youtube)
Muse
40,866
10,221
For me, it would be their smallest unit that could work, evidently, the 9000BTU. The page for it says Product Video but I see nothing there for that, no link. I'm unclear reading their online stuff how you install, where you install, what's required. I'm VERY DIY, so could probably do that. I guess I can just hit up YT and get an idea what it would entail. As stated above in this thread, I have a window AC in my bedroom with a couple 200mm computer fans right next to it in the same window. It's a nice combo. But that setup is for cooling only. I'm wondering if the heat pump could go where those are.
Um, or maybe this goes in the attic with piping into the spaces. Seems to want higher voltage than the standard 120v around here. Doable, of course.
ultimatebob
25,134
2,450
I never liked the oil filled radiator space heaters. They seem to only heat a 4 foot circle of space around the heater, and that's about it.
The ones with a blower fan are better at heating a room. If you want to class up the joint, I'd recommend getting something like one of these "fireplace" heaters:
Here's a picture of one of these things "in action" over Christmas:
deadlyapp
6,670
744
Every house in US (generally) has capability of 240V AC, you just only wire half of it to get 120V for standard outlets and lighting.
Reactions: Muse
ultimatebob
25,134
2,450
I have a Mitsubishi Mini-split heat pump in my kitchen. It works great, but they are expensive.
Muse
40,866
10,221
Muse
40,866
10,221
I wonder what the catch is, that is pretty cheap.... $999.
Probably no warranty or anything. But if it's the real thing and not some kind of knock off that's not bad still.
Amazon's page says the manufacturer's 5 year warranty is in effect. My ringup (if I confirm): 738.66 at amazon, USD including tax.
I'm off to Costco now, where the first thing I do is return my two Lasko CT22445 stinky space heaters.
Nov 17, 2019
13,298
7,878
One other issue with the splits, is you have to have a place outside for the main unit and that's where the power needs to be. They should be on the ground, but I've seen them on shelves or platforms.
Not sure of the brand of the gizmo you're looking at.
Reactions: Ken g6
